FS: Function & Form II
These are oem style, I have them and if you search in the suspension forum, there is a thread of oem vs true. Basically it is just whatever you want/prefer. Great coilovers, I love mine. You might want to check with f&f for fitting 350z I think your rear strut oem bolt might be a different size than for g35s. I would check on that before you buy them.
IMO I see some parts selling for too cheap, some people get used to that and expect it. 675 isn't bad. If you're in CA you're gonna pay taxes even though its 8 something shipped so youre looking at roughly 950 bucks. 675 is roughly 30% off which seems quite reasonable. Doesn't have to be half off just because it's used or because someone else may be sellin for less.
Also, OEM vs true....with an OEM style coilover setup there is less stress on the shock since you have a spring in the spring bucket. Only advantage I can think of for true coilovers is the use of toe arms, which would replace the spring bucket. A drawback is if you get UAS bags, you're going to need to custom make an adjustable spring bucket since the bags mount where the spring bucket is.
GLWS.
GLWS.
OP you really need a picture with a piece of paper with your name on it next to these. Whether it's a shot of the upper mount in your engine bay where the dampener adjustment **** is or whether you jack up the car and take one of them in the fender well... You have zero feedback and very few posts and I'm surprised this isn't closed already. I got jacked for about this same amount of money by a guy on ebay for some F&F's when I was looking to replace my older version F&F's and for all I know you could be the same cat...
Not trying to jack your thread, but there's way too many con games getting played these days.
Oem or true generally does boil down to what people want/prefer. That does not mean it's thought out or the implication's actually researched. Short of a handfull of prepped race cars I can count on one hand in Japan, no Z or G owner has or could do the modification's that make a truecoilover a non issue. I don't and will not run that type of setup for a reason.
