FS: Swift springs for coilovers
Old Dec 1, 2012 | 03:02 PM
FlyingLumpia's Avatar
Springs are sold, but still have the spacer that will raise the rears if you are almost maxed out.
Also I have some spacers for those peeps that want to raise their rears for the winter and not have the saggy butt look
For the spacer to raise it up more, I will go with 25 shipped.
Thanks for looking. Btw low ballers will be ignored and I believe my prices are pretty fair.
Old Dec 1, 2012 | 03:22 PM
soundmike's Avatar
Great deal! I just ordered Swifts for my BC's and they cost $85/each brand new. This is practically half-off.
Plus, it's from a Flying Lumpia. Hope it's the fresh kind ;-)
Old Dec 1, 2012 | 04:06 PM
SN00P's Avatar
CLUB MODERATOR
Dumb question ... I just ordered bc 10k springs for the rear ... What's the difference between those 10k an swift 10k rates ??
Old Dec 1, 2012 | 05:05 PM
soundmike's Avatar
Swift uses a different material for their springs and are highly regarded as one of the better spring-makers in the industry. Their linear rates are also more consistent across the entire compression range.
Swift springs typically also has less coils, which helps reduce weight which in turn makes it more responsive from lesser unsprung weight.
Old Dec 2, 2012 | 11:35 AM
bump
Old Dec 3, 2012 | 10:53 PM
bump
Old Dec 6, 2012 | 09:40 PM
bump
Old Dec 10, 2012 | 03:49 AM
TGMcCoy's Avatar
Trying to research, but do you have any idea if either the front or rears would workk with stance gr+ true coils? I know these were with BC oem style---
Not even sure if throwing these on as is a good idea.... I do want swift springs for my stance though. Thanks
Old Dec 12, 2012 | 10:23 AM
The best bet is to measure your spring on the stance coilover. I want to say yes they will. What is your rates now?.
Old Dec 12, 2012 | 11:28 AM
TGMcCoy's Avatar
12k front 5k rear-- stock stance springs. I think there would be a problem cuz these are OEM.
Serges needs to get these!
Old Dec 12, 2012 | 11:13 PM
The fronts will work. The rears should work also, but 10k would be really stiff. I converted my bc racing to a true in the rear. I do think they will work better with a oem style.
Old Dec 16, 2012 | 01:29 AM
serges's Avatar
someones say my name!! lol
is this gunna make my ride more comfortable?
im on bc's right now!
Old Dec 16, 2012 | 02:50 AM
TGMcCoy's Avatar
Yep- I did. Do it!
Old Dec 16, 2012 | 09:17 AM
serges's Avatar
Once my galaxy s3 sells I will get these
Old Dec 17, 2012 | 11:19 PM
Just let me know.
