SPC Camber Kit $375-F / $169-R Shipped! KW V3 $1749! Swift Springs $275! Shipped!!
Sep 24, 2007 | 09:19 PM
Hey guys were offering the best deals on some of the most popular suspension components out there for the 350Z. All prices include shipping.
SPC Front Camber/Caster System
$375 Shipped to the Door
Save your tires! The SPC Front System finally allows 350Z owners to adjust the suspension back to spec saving your tires.
-Camber Adjustment Range: -1.5° to +3.5°
-Caster Adjustment Range: ±1.0°-
-Heavy Duty Upper Ball Joints
SPC Rear Camber/Toe System
$169 Shipped to the Door
-Camber Adjustment range: ±4.00
-Toe Adjustment Range: ±3.00
-Heavy Duty Hardware
Coilovers!
KW Variant 3
$1749 Shipped to the Door
Independently adjustable damping technology. Rebound and compression damping. Inox-line stainless steel technology at no extra charge. Individual height adjustment.German TUEV-tested adjustment parameters. High-quality components for long life
-14 Level Adjustable Compression Damping
-Infinitely Adjustable Rebound Damping
-Unique, Independently Functioning Damping Power Adjustment
RS*R Sports*I Coilovers
$1350 Shipped to the Door
Built with Ti2000 coil springs (Titanium composite) and 36-way dampening adjustability are just some of the benefits of this system. Ride height is also adjustable not only by spring height, but shock body length as well to give you the opportunity to put just the right amount of preload on the springs for added balance.
-36 Way Adjustable Rebound and Compression
-Lightweight Titanium Composite Springs
-Polyurethane Bushings Reduce Road Noise
Apexi N1 Damper ExV
$1299 Shipped to the Door
The Expert Type V (ExV) is a full coilover suspension featuring a threaded base for precise ride height adjustment without compromising shock or spring travel. High performance upper mounts and 32 way ride quality adjustment for street cars that are used at the track as well.
-Threaded Shock Base for Precise Ride Height Adjustment
-Strong Body Will Not Strip
Swift Sport Springs
$275 Shipped to the Door
- 6 kg/mm Front, 6.5 kg/mm Rear
- 0.8" lower Front, 0.6" lower Rear
- uses H5S.TW material
- Manufactured with cold winding coiling technology
- Lighter in weight, fewer coils, yet consistent linear spring rate
- Superior Durability, does not sag or fatigue over time.
Oct 1, 2007 | 12:45 PM
how much would it be for the spc front and rear camber kit pickup? do u have the spL front camber if so how much?
Oct 1, 2007 | 02:49 PM
Sorry we don't carry spl, but the SPC fornt and rear kit would be $565.69 after tax, picked up.
Thanks,
Gruppe-S
Oct 5, 2007 | 02:54 AM
SPC Rear Camber/Toe System revised???
pm me the price~
Oct 5, 2007 | 03:23 PM
$169 shipped for the rear.
Oct 15, 2007 | 01:31 AM
same price ($375) shipped to vancouver, bc canada?
Oct 15, 2007 | 01:32 AM
please pm me
Oct 15, 2007 | 01:36 AM
how much for rear camber kit.. picked up?
Oct 15, 2007 | 01:37 AM
and how soon can you ship it out/
Oct 15, 2007 | 04:54 PM
johnjayb $172.40 picked up.
Crespo pm sent!
Oct 16, 2007 | 02:46 AM
172.40 picked up??? Shouldn't I just ship it since its 169 shipped?
Oct 16, 2007 | 04:46 PM
$169 shipped does not include tax, california needs to add tax.
Oct 17, 2007 | 10:10 PM
Bump Guys
Gruppe-S
