HKS Hypermax III's are out...
Old Apr 13, 2008 | 02:23 PM
Sandy@ART's Avatar
Arrow HKS Hypermax III's are out...
HKS Hypermax III’s are out and are in stock. Please PM for special pricing.
Standard HKS Hypermax III (coupe only)
Spring rate is 9/9 – tuned
Series Concept: Designed and tuned for street application / daily driving.
With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS' all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
In addition, the Hipermax III is shock-body adjustable (most applications) to allow vehicle height adjustment without affecting spring rate and piston stroke. With the Hipermax III’s range of adjustability, precise corner balancing can be achieved. Chrome-plated cylinder shafts provide excellent durability and newly-design rubber upper mounts reduce harshness. (For most applications, optional spherical bearing mounts are also available for enhanced steering feedback.)
Key Features:
• Hiper Linear Piston Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
• Strengthened rubber upper mounts enhanced durability
• Monotube design
• Shock-body length adjustable (most applications)
• 65mm diameter springs Cold wound and manufactured in-house at HKS to ensure quality and consistency
• Stainless lock nut & ride height adjuster feature anti-rust & corrosion characteristics for enhanced durability.
• 30-way adjustable dampening
• Hard chrome-plated cylinder shaft
• Non-electrolysis Nickel plated shock bodies provide durability in severe weather conditions.
• Pillowball upper mounts optional on certain applications
• Dustboots standard
• 1 year limited warranty
HKS Hypermax III Sport (coupe only)
Spring rate is 11/12 - tuned
Series Concept: Designed and tuned for competition / track.
The Hipermax III Sport series has firmer spring rates and valving to take advantage of the smoother, more consistent pavement of race tracks allowing quicker, more precise transient response and instant direction changes necessary in competition. In addition, the Hipermax III Sport incorporates HKS' all-new Hiper Linear Piston fluid-channel system, shock-body length adjustability (most applications) and ultra-thick chrome plating of the cylinder shaft for excellent durability and reduced stiction (static friction). Spherical bearings, for precise steering and feedback, are standard - but reinforced, rubber upper mounts are available for those seeking reduced vibration from less-than-smooth pavement.
Key Features:
• Hiper Linear Piston Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements.. As piston speed increases, dampening rate linearly increases.
• Pillowball upper mounts standard
• Monotube design
• 65mm diameter springs - Cold wound and manufactured in-house at HKS to ensure quality and consistency
• Lightweight Aluminum lock nut & ride height adjuster
Old Apr 14, 2008 | 06:14 PM
Sandy@ART's Avatar
PM's answered..
Old Apr 15, 2008 | 03:46 AM
Sandy@ART's Avatar
PM sent
Old Apr 15, 2008 | 01:23 PM
imminence's Avatar
Are the Hypermax III's available for the 2007+ sedans yet?
Old Apr 15, 2008 | 08:41 PM
TroysG's Avatar
price on the standard for an 04 coupe shipped to L4N 8X9
Old Apr 15, 2008 | 09:12 PM
Xblackg35X's Avatar
shipped to 71112
Old Apr 16, 2008 | 12:56 AM
Sandy@ART's Avatar
According to HKS the coilover is only available for the coupe. sorry
Old Apr 16, 2008 | 01:01 AM
Sandy@ART's Avatar
PM's answered
Old Apr 16, 2008 | 08:30 AM
Sandy@ART's Avatar
Troy,
You have another PM..
Old Apr 18, 2008 | 04:38 PM
Sandy@ART's Avatar
ttt
Old Apr 19, 2008 | 05:01 AM
Sandy@ART's Avatar
All pm's answered..
Old Apr 20, 2008 | 01:50 PM
Sandy@ART's Avatar
PM's answered..
Old Apr 22, 2008 | 07:15 AM
Sandy@ART's Avatar
All PM's answered
Old Apr 24, 2008 | 02:28 AM
Sandy@ART's Avatar
all pm's sent
Old Apr 25, 2008 | 08:49 PM
Mike@ART's Avatar
Friday Bump!
