All Competitors Beat SPC Camber Kits $520-Ohlins DFV-KW V3 Ready To Ship
Old Nov 12, 2008 | 07:18 PM
gruppe-s's Avatar
Former Sponsor
Best Suspension Deal of The Year!!! All competitors prices beat... Just bring me a PM or email and we will beat their price!!!
SPC Camber Kit
The SPC Adjustable control arms you can finally tune camber and caster .
SPC Performance's new arm/shim kit has more than enough camber and caster change to correct cars that have been lowered, or for vehicles used in drifting, allowing for precise changes when fine tuning suspension alignment angles necessary when racing or drifting.
Front Arms
$350 Shipped
Rear Arms
$175 Shipped
F&R Combo
$520 Shipped
PM For Sedan Price
Eibach Lowering Springs
1.2"/1.2" Drop
$250 Shipped
Tein Lowering Springs
S. Tech
.7"/.6" Drop
$250 Shipped
***Open Box Display Sale-1 Set Each in Stock***
H. Tech
.3"/.2" Drop
$250 Shipped
Tanabe Lowering Springs
NF
1.2"/1.2" Drop
$195 Shipped
GF
1.0"/1.2" Drop
$195 Shipped
RSR Down Springs
Open Box Display
1.0"/1.2" Drop
$199 Shipped
Tein Coilovers
Best Price Anywhere
Basic
Super Street
Flex
MonoFlex
$PM For Price
KW V3 Coilovers
Priced Super Cheap
Used by some of the top drift team in the world. During manufacturing of KW Coilover suspensions, the highest quality materials are used to produce individual suspension solutions that enable customers to adjust vehicle height according to their wishes and needs.
Function:
• Infinitely adjustable within german TUEV-tested adjustment parameters
• Shortened struts for increased spring travel
• Trapezoidal threads for simple height adjustment
• Three different damping technologies for individual adjustment
• Elastomer bump stops with integrated dust boot protection
• Easy to read documentation
• Ready to use comprehensive solutions
• Visually perfect – safe and unique motion dynamics
Quality:
• Strut housings in inox-line stainless steel technology
• Anodized aluminum spring collars and add-on pieces
• High-quality, high-tensile racing springs
• Special ventilation and sealing system
• High-quality damping components
• Hardened, chromium-plated piston rods
• Special guide and sealing systems
• Pistons with V-shaped Teflon seals – optimal sealing with minimal friction – temperature-resistant, durable damping technology
Price too Low To Post. $PM For Price
HKS Hipermax 3
Best Ride Quality
HIPERMAX III
Series Concept: Designed and tuned for street application / daily driving.
With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS' all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
• Strengthened rubber upper mounts – enhanced durability
• Monotube design
• Shock-body length adjustable (most applications)
• 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency
• Stainless lock nut & ride height adjuster – feature anti-rust & corrosion characteristics for enhanced durability.
• 30-way adjustable dampening
HIPERMAX III SPORT
Series Concept: Designed and tuned for competition / track.
The Hipermax III Sport series has firmer spring rates and valving to take advantage of the smoother, more consistent pavement of race tracks allowing quicker, more precise transient response and instant direction changes necessary in competition. In addition, the Hipermax III Sport incorporates HKS' all-new Hiper Linear Piston fluid-channel system, shock-body length adjustability (most applications) and ultra-thick chrome plating of the cylinder shaft for excellent durability and reduced stiction (static friction). Spherical bearings, for precise steering and feedback, are standard - but reinforced, rubber upper mounts are available for those seeking reduced vibration from less-than-smooth pavement.
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements.. As piston speed increases, dampening rate linearly increases.
• Pillowball upper mounts standard
• Monotube design
Hipermax III
$PM For Price
Hipermax III Sport
$Pm For Price
Ohlins DFV
Ultimate Track Suspension
Not much can be said about these other than these are the Ultimate in Tack Performance. The Ohlins DFV suspension system is the latest design from Ohlins which incorporates a a PCV valve on the compression and extension sides of the shock. This builds on the award winning PCV suspension model for even greater performance. Super forged duralumin construction with final teflon. Super lightweight with high stiffness. Designed to balance ride comfort and vastly improved suspension performance. Price is for the complete kit, including springs
Nissan - 350Z - Z33 - F:10 R:7 kg/mm
Priced Super Low. Pm for Price
Old Nov 24, 2008 | 02:52 PM
gruppe-s's Avatar
Former Sponsor
Bump!
Old Nov 25, 2008 | 02:19 PM
gruppe-s's Avatar
Former Sponsor
Bump!
Old Nov 25, 2008 | 03:46 PM
Bobyl573's Avatar
spc rear arms include toe bolts? and also price for tein basics for g35 coupe shipped to 94539 thanks
Old Nov 25, 2008 | 07:16 PM
gruppe-s's Avatar
Former Sponsor
Pm'd
Old Nov 26, 2008 | 02:11 PM
gruppe-s's Avatar
Former Sponsor
Bump!
Old Nov 26, 2008 | 02:56 PM
absolutg's Avatar
workin...
price for sedan front/rear camber kits, and does it include the toe bolts, shipped to 98006
Old Dec 1, 2008 | 05:20 PM
gruppe-s's Avatar
Former Sponsor
Monday Bump
Old Dec 3, 2008 | 04:31 PM
gruppe-s's Avatar
Former Sponsor
Countdown to Xmas Sale...
From now on untill X-Mas. Gruppe-S will be offering a new daily special each day. This will be a 1 day sale. Everyday the sale item changes. Remember 1 day sale only for each item. Dont miss out.
Countown To Christmas Sale
Old Dec 9, 2008 | 05:02 PM
gruppe-s's Avatar
Former Sponsor
bump!
Old Dec 9, 2008 | 05:53 PM
gruppe-s's Avatar
Former Sponsor
Free Hankook T Shirt and Hankook Hat Day
Free Hankook T Shirt/ Free Hankook Hat
Old Dec 11, 2008 | 03:09 PM
gruppe-s's Avatar
Former Sponsor
Bump!
Old Dec 14, 2008 | 01:49 PM
100wattz's Avatar
how long does shipping take to 95831? this includes toe control right?
Old Dec 14, 2008 | 02:39 PM
E-Ticket Ride's Avatar
PM price for Hipermax III and IIIs to 96825
Also, what's the minimum drop on the HKS?
Old Dec 14, 2008 | 05:23 PM
g35man04's Avatar
CLUB MODERATOR
price on HKS shipped or KW V3 Coilovers to 75069?
also I was curious if you have a replacement red Rubber grommet by chance for the Front SPC Camber Upper A Arm. Mine has come off..I am not sure if that is a good or bad thing....
