Megan Racing Coilovers Street/Track!!
Old Nov 8, 2012 | 02:46 PM
  #301
mrwong@statik's Avatar
Bump
Old Nov 9, 2012 | 02:44 PM
  #302
Bump
Old Nov 23, 2012 | 04:33 AM
  #303
Happy Thanksgiving!
Old Dec 11, 2012 | 04:08 PM
  #304
Bump
Old Dec 19, 2012 | 06:16 PM
  #305
Bump
Old Jan 15, 2013 | 12:28 AM
  #306
Bump
Old Jan 15, 2013 | 01:21 PM
  #307
norm24heath's Avatar
How much shipped m1c1s1 Toronto Canada I have a 2007 g35x
Originally Posted by mrwong@statik
*FREE SHIPPING*
*FREE SQUASH AIR FRESHENER WITH ORDERS OVER $100*
Infiniti G35
Model Number : MR-CDK-N3Z
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in **** at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: 10kg Front and 8kg Rear
- 32 Levels of Adjustable Damper
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
-Street Model and Track Model Available.
PM for Best Pricing!!
Old Jan 15, 2013 | 04:37 PM
  #308
$910 shipped.
Old Jan 15, 2013 | 04:43 PM
  #309
Do they come with the extenders so I can adjust the settings while on the car
$910 shipped.
Old Jan 15, 2013 | 04:48 PM
  #310
Pitbull516's Avatar
How much shipped to 11520
04 G35 Sedan Rwd
Old Jan 15, 2013 | 05:46 PM
  #311
Yes
04 G35 Sedan Rwd
pm'd
Old Jan 20, 2013 | 02:14 AM
  #312
Bump
Old Jan 23, 2013 | 02:22 AM
  #313
Bump
Old Jan 23, 2013 | 01:08 PM
  #314
vgran's Avatar
price
how much shiped to 92507
Old Jan 25, 2013 | 03:16 PM
  #315
Bump
