Megan Racing Coilovers Street/Track!!
Old Jan 28, 2009 | 03:10 AM
mrwong@statik's Avatar
*FREE SHIPPING*
*FREE SQUASH AIR FRESHENER WITH ORDERS OVER $100*
Infiniti G35
Model Number : MR-CDK-N3Z
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in **** at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: 10kg Front and 8kg Rear
- 32 Levels of Adjustable Damper
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
-Street Model and Track Model Available.
PM for Best Pricing!!
Old Feb 2, 2009 | 05:36 PM
pms replied.
Old Feb 4, 2009 | 06:40 PM
price adjustment...pms replied..
Old Feb 4, 2009 | 07:34 PM
SxExCx's Avatar
OK, so I decided I would ignore the nay-sayers and give Megan Racing a chance to prove itself. I purchased the street series about a week ago and have been riding on them for about 5 days. My expectations were low....here are my impressions:
-the overall quality is as good as any other coilover I have seen; the machine work is top notch.
-the features are great and even included damper adjustment extensions for the rear
-the install was pretty simple
-they have more height adjustment than you will ever need
-the ride quality a very nice
-the handling is great
For the price, you cant beat them.
I did not purchase them from this vendor nor am I affiliated with Megan...I am just happy to share my positive experience.
Old Feb 4, 2009 | 07:40 PM
nice thanks for the feed back
Old Feb 4, 2009 | 08:00 PM
O HELLA OEM's Avatar
shipped to 15122
and will this fit under a NRG V2 strut bar?
Old Feb 6, 2009 | 04:26 PM
pms replied...
Old Feb 9, 2009 | 07:45 PM
PPGFREAK's Avatar
ok ok im thinking this would be a good thing to do. shipping to 04085
Thanks
Old Feb 12, 2009 | 12:34 PM
benwaballs's Avatar
shipped to 48439 street ones
Old Feb 13, 2009 | 06:28 PM
AllNatural's Avatar
shipped to 96816, and do these have and edfc?
Old Feb 14, 2009 | 01:32 PM
troll's G35's Avatar
Is there any for the 08 sedans or will the g37s fit, if so how much shipped to 93725? Street use thank you.
Old Feb 14, 2009 | 11:46 PM
blk-g35sedan6mt's Avatar
05-06 sport sedan price please!!!
Old Feb 15, 2009 | 01:05 AM
jeedup35's Avatar
shipped to 20164 please??????
Old Feb 15, 2009 | 01:02 PM
Genkiboi8o8's Avatar
shipped to 96744?
Old Feb 15, 2009 | 02:02 PM
a_phamm's Avatar
90660
