STANCE LX+ Coilovers, Comfort, Performance, Quality, Fully Adjustable
Old May 16, 2010 | 02:17 AM
  #256
UhhPogiG35's Avatar
price shipped to 94017 thx
Old May 17, 2010 | 11:30 AM
  #257
THMotorsports's Avatar
All PMs sent out!!!
Old May 18, 2010 | 12:13 PM
  #258
LEK's Avatar
LEK
That Guy
price to 22031
Old May 18, 2010 | 08:45 PM
  #259
jayk's Avatar
Is this adjustment enough not to need front camber kit?
Adjustable Camber Uppermount
http://stance-usa.com/sus/products/coilovers/pro
Old May 19, 2010 | 04:05 PM
  #260
Originally Posted by LEK
price to 22031
PM sent
Camber plates are not available for the G and Z chassis...sorry.
SPC camber kits are a must!!!
Old May 19, 2010 | 04:24 PM
  #261
Raaaaaaaandy's Avatar
Price shipped to 32828... Thanks
Old May 20, 2010 | 01:02 PM
  #262
craigmac's Avatar
price shipped to 92114
Old May 20, 2010 | 01:20 PM
  #263
PM sent
Old May 21, 2010 | 01:10 PM
  #264
Gsedan35's Avatar
Originally Posted by THMotorsports
OEM type is progressive rear. So saying 11K is not that accurate.
5K on the rear of the TRUE type is a linear spring rate...it will be stiffer than that 11K progressive rate.
My favorite is the GR+ TRUE type single rear FTW!!!!
-Adam
Well,....not to beat anyone up but,..........
The oem rear spring is not progressive as seen in the product photo below. No coil bind to effect rate change, no coil diameter change and I have yet to see anyone go to the expence if using different wire diameter's.
When you look at wheel rate between a 280lbs truecoilover spring and a 616lbs rear spring in the oem location the actual rates seen at the wheels are actually pretty close
280lbs truecoilover rear wheel rate since the damper/spring mounts directly to the hub =280lbs
616lbs rear spring in the oem location wheel rate =259lbs.
Only a 21lbs spread between the two.
Old May 24, 2010 | 11:08 AM
  #265
nice write up and pics...good info. Stance simply calls them the progressive rates...so we do too to differentiate the two.
-Adam
Old Jul 6, 2010 | 07:35 PM
  #266
VxLyf3's Avatar
are these comfortable for the streets? cuz thats all i be doing
Old Jul 6, 2010 | 10:11 PM
  #267
6spSEDANFTW!'s Avatar
price shipped 95621
Old Jul 7, 2010 | 02:49 PM
  #268
LX+ are a nice street setup...but best drop range would be achieved with the GR+ TRUE type
All PMs sent
Old Jul 7, 2010 | 03:09 PM
  #269
jrhykushi's Avatar
shipped to 11214
Old Jul 8, 2010 | 04:53 PM
  #270
Originally Posted by jrhykushi
shipped to 11214
PM sent
