Ichiba Wheel Spacers...5/10/15/20/25 Both Versions available!
Looking for Spacers? Everywhere not cheap enough? Well look no further.
Shoot me a PM and I'll be more then happy to hook you guys up!
Description:
Wheel Spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
Spec:
Bolt Pattern: 5/114.3
Center Bore: 66.2
Thread: 12x1.25
Longer Studs Included
Sold as one pair (2pcs) with 10pcs longer studs.
Ichiba NS-50205 Spacer V1 5mm
Ichiba NS-50210 Spacer V1 10mm
Ichiba NS-50215 Spacer V1 15mm
Ichiba NS-50220 Spacer V1 20mm
Description:
Version II wheel spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. Each wheel spacers are two pieces design with pressed studs. Now it's time to bolt-on without any swap studs hassles. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
Spec:
Center Bore: 66.2
Thread: 12x1.25
Note:
Sold as one pair (2pcs) with 10pcs nuts
Ichiba WS-25511466A Spacer V2 15mm
Ichiba WS-25511466B Spacer V2 20mm
Ichiba WS-25511466C Spacer V2 25mm
~PM~ For Pricing too low to post!
Description:
Spec:
Center Bore: 66.2
Thread: 12x1.25
Description:
Spec:
Center Bore: 66.2
Thread: 12x1.25
Note:
jookyshank
I haz hugz to givez
close
- Join DateApr 2009
- LocationDenver, Co
iTrader Positive Feedback100
iTrader Feedback Score(13)
Liked:286 Times in 263 Posts
Hey there,
Price for 25mm V2's all around to 99216 please
Danke
Danke
