♦♦♦ NEW---ISC Suspension Coilovers ♦♦♦
Old Jan 5, 2011 | 08:47 PM
Marinelli Motorsports's Avatar
Offered in Street Sport and Racing/Drift
32 Step Damper Adjustable
•Precise control damp valve
•Operates smoothly on all road surfaces
•Expansion/Suppression of shock adjustment
Piston Rod Design
•High rigidity steel piston rods
•Meets with race/sport standards
Spring
•Made from high quality SAE9254 steel
•Tested over 500,000 times on compression inspection with less than 5% deformation.
•Choose from Street/Sport or Track/Race (spring rates vary depending on application, for specs check the application guide or ask us when you order, custom spring rates are free).
Ride Height Adjustable
•Full length height adjustable
•Bound adjustable with separate spring locks
•High quality T6061 aluminium alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force
Aluminium Bracket
•Made from T6061 aluminium alloy by organic shaping to lighten weight and increase handling performance
•Specifically anodised surface to prevent inside corrosion and surface rust
•On various models camber can also be adjusted via the bracket as well as the camber tops
Single Cylinder Design
•Larger cylinder and piston design to advance driving stability and dexterity
Please PM for pricing!!!
Old Jan 6, 2011 | 07:55 PM
All PMs replied!!!
Old Jan 7, 2011 | 08:22 PM
All PMs replied!!!
Old Jan 8, 2011 | 09:18 PM
All PMs replied!!!
Old Jan 9, 2011 | 07:55 PM
All PMs replied!!!
Old Jan 10, 2011 | 08:27 PM
Bump!!!!
Old Jan 11, 2011 | 07:16 PM
Bump!!!
Old Jan 12, 2011 | 07:41 PM
Bump!!!
Old Jan 13, 2011 | 07:53 PM
Bump!!!
Old Jan 14, 2011 | 06:57 PM
Friday Bump!!!
Old Jan 16, 2011 | 02:05 PM
Bump!!!
Old Jan 18, 2011 | 07:18 PM
Bump!!!
Old Jan 19, 2011 | 07:20 PM
To the Top!!!
Old Jan 20, 2011 | 06:10 AM
Jg35skyline's Avatar
g35 coupe shipped to 11510
Old Jan 21, 2011 | 09:15 PM
Friday Bump!!!!
