Megan Racing Coilovers - Camber Arms & More!! - Eibach Springs!!
Old Jul 26, 2011 | 02:28 AM
Coz@Czp's Avatar
_________________________
Megan Racing G35 MR-CDK-N3ZTS Track Series 32 Way
Description:For those who demand the absolute most in handling and performance from their vehicle, Megan Racing has developed a new series of fully adjustable Coil-Over Damper kits for limited applications. The new Track-Series Coil-over Damper Kit surely stands out above the rest with the dependability and performance that Megan Racing suspension products are known for. With a gunmetal finish for the brackets and coated springs for durability, it is apparent that the Megan Racing Track-Series dampers mean business. However, beyond their aggressive appearance stands the true essence of these Dampers. The increased spring rates, mated with more aggressively valved dampers, stiffer shock setting, and heavy-duty piston construction add up to a suspension system that out-performs most competing suspensions that retail for almost twice the price. [/SIZE]
Megan Racing G35 MR-CDK-N3Z Street Series Coil-over 32 Way
Description:Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 levels of damper force adjustment, separate spring perch height and shock length adjustment allowing you to retain full suspension stroke and to fine tune your suspension characteristics. These damper kits are then perfectly matched with front and rear Pillow Ball upper mounts, including camber plates integrated with the upper Pillow Ball mounts on strut-type suspension applications. [/SIZE]
Megan Racing G35 Roll Center Adjuster
Description:Megan Racing has unveiled our line of reinforced suspension arms that offer the strength and adjustment that any competition vehicle will ever need. Constructed of high-strength steel alloys that offer durability, strength and yet remain light-weight, these control arms have been track tested for months in road race, autocross and drift events to assure quality and performance.[/SIZE]
Megan Racing Rear Camber Arms G35
Megan Racing Rear Camber Lower Arm G35
Megan Racing Rear Caster/Toe Links G35
Eibach G35 Pro-Kit Springs
PM me for best pricing or with any questions you have.
Old Jul 27, 2011 | 01:36 PM
Coz@Czp's Avatar
Bumped
Old Jul 29, 2011 | 04:12 AM
Coz@Czp's Avatar
Bump!!
Old Aug 2, 2011 | 07:34 PM
Coz@Czp's Avatar
Bump!
Old Aug 5, 2011 | 11:18 PM
Coz@Czp's Avatar
Bumped!!
jsimonk
Dec 22, 2023 03:49 PM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
cbax
Aug 17, 2015 07:41 AM
