SPC and Ichiba camber kits. BC BR Coilovers!!!
Old Jan 19, 2013 | 11:37 AM
  #241
julianG7's Avatar
Bc voils price shipped to 92507
Old Jan 23, 2013 | 04:29 PM
  #242
abb2autodesigns's Avatar
Bumb
Thanks
Adrian
Old Jan 27, 2013 | 05:03 PM
  #243
Sunday bump
Charles
Old Jan 28, 2013 | 12:00 AM
  #244
LxV Socal's Avatar
Price for front SPC camber kit?
Old Jan 28, 2013 | 07:41 AM
  #245
norm24heath's Avatar
Do you have a set for a 2007 g35x? How much for the coilovers with spc f+r camber kits shipped to m1c1s1 Toronto Canada?
Originally Posted by b2autodesigns
Hello Guys.
Got these in stock ready to ship.
SPC Camber Kit
Need your SPC camber kits in a hurry. No need to worry. Free 2nd day air shipping upgrade. Get them fast!!!
After lowering the ride height of your G35. Excessive negative camber can actually hurt your traction, tire wear and cornering performance. The complete SPC Pro-Alignment front and rear camber w/rear toe kits replace the limited stock alignment adjustment and let you fine tune the handling and traction characteristics of your car. Now you can set up your ride for any driving scenario, from the street to the strip and anything in between. These kits will NOT fit cars with active steering
03-07 G35 Coupe/Sedan
07+ G35 Sedan/G37 Coupe
Front kit Adjustment range: Camber: -2.5 degrees to +2.5 degrees.
Rear kit w/toe bolt Adjustment range: Camber ±4.00 degree Toe ±3.00 degree
Please pm for best pricing.
BC BR Coilovers package's.
Mono-tube shock design
30 levels of damping force
Pillowball mounts and adjustable camber plates included*
Adjustable rear camber plates available
Separate Full length height adjustable
Inverted and Non-Inverted setups
One year warranty
Rebuildable
Technical
Coilovers use 46mm pistons and 53mm shock housings.
Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
Patented concave lower locking ring, to prevent unseating
Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
Iron lower brackets on MacPherson struts to ensure rigidity
Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
2 step coating process utilizing nickel and chromium plating to prevent corrosion
BR-Type
Package BC coilovers w/Ichiba rear camber kit w/toe bolt shipped $1030.00.
Package BC Coilovers w/SPC Rear camber kit w/toe bolt shipped $1079.00
Please pm me with any questions you might have. Fast shipping as always
Thanks
Charles
Old Jan 28, 2013 | 09:52 AM
  #246
Both pm sent
Thanks
Charles
Old Feb 1, 2013 | 11:17 AM
  #247
Friday bump
Charles
Old Feb 4, 2013 | 01:36 PM
  #248
Message me with any questions.
Charles
Old Feb 7, 2013 | 02:59 PM
  #249
Gettingupagain's Avatar
Price of rear camber kit with toe bolt shipped to 37042
Old Feb 10, 2013 | 04:39 PM
  #250
Message me for best pricing.
Charles
Old Feb 12, 2013 | 01:41 PM
  #251
All pm sent
Charles
Old Feb 14, 2013 | 02:35 PM
  #252
Charles
Old Feb 16, 2013 | 01:31 AM
  #253
Scrildo's Avatar
Price of spc a arms and rear camber arms shipped to raleigh nc 27616 please. This is for a 06 G35 sedan 6MT.
Old Feb 17, 2013 | 04:40 PM
  #254
epborden's Avatar
Price to 28083
2005 G35x
BC's with 10k front and 8k rear springs + SPC front/rear camber kits
Can you do this? Send me a price! Thanks!
Old Feb 17, 2013 | 05:16 PM
  #255
Both pm sent
Charles
