SPC and Ichiba camber kits. BC BR Coilovers!!!
Old Sep 20, 2011 | 07:25 PM
b2autodesigns's Avatar
Hello Guys.
Got these in stock ready to ship.
SPC Camber Kit
After lowering the ride height of your G35. Excessive negative camber can actually hurt your traction, tire wear and cornering performance. The complete SPC Pro-Alignment front and rear camber w/rear toe kits replace the limited stock alignment adjustment and let you fine tune the handling and traction characteristics of your car. Now you can set up your ride for any driving scenario, from the street to the strip and anything in between. These kits will NOT fit cars with active steering
03-07 G35 Coupe/Sedan
07+ G35 Sedan/G37 Coupe
Front kit Adjustment range: Camber: -2.5 degrees to +2.5 degrees.
Rear kit w/toe bolt Adjustment range: Camber ±4.00 degree Toe ±3.00 degree
Please pm for best pricing.
BC BR Coilovers package's.
Mono-tube shock design
30 levels of damping force
Pillowball mounts and adjustable camber plates included*
Adjustable rear camber plates available
Separate Full length height adjustable
Inverted and Non-Inverted setups
One year warranty
Rebuildable
Technical
Coilovers use 46mm pistons and 53mm shock housings.
Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
Patented concave lower locking ring, to prevent unseating
Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
Iron lower brackets on MacPherson struts to ensure rigidity
Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
2 step coating process utilizing nickel and chromium plating to prevent corrosion
BR-Type
BC BR coilovers with Swift spring upgrade.
Package BC Coilovers w/SPC Rear camber kit w/toe bolt shipped $1079.00
Please pm me with any questions you might have. Fast shipping as always
Thanks
Charles
Old Sep 24, 2011 | 07:14 PM
[B]Join us on Facebook [/B
]https://www.facebook.com/pages/B2-Auto-Designs/165793298063?ref=ts
Thanks
Charles
Old Sep 24, 2011 | 09:07 PM
joek19522's Avatar
SPC Camber Kit
...price of the front and rear SPC camber kit and toe bolt to 18064
Old Sep 28, 2011 | 11:38 AM
pm sent
Thanks
Charles
Old Sep 29, 2011 | 08:48 PM
TonyG-'s Avatar
Price on rear ichiba camber kit shipped to 31645?
Old Oct 4, 2011 | 11:56 AM
pm sent
Thanks
Charles
Old Oct 8, 2011 | 01:06 PM
bump
Thanks
Charles
Old Oct 8, 2011 | 01:47 PM
alpa_chino's Avatar
Spc front and rear camber kit to 78230
Old Oct 8, 2011 | 05:06 PM
ld636's Avatar
spc front and rear camber kit shipped to 95210 thanks
Old Oct 11, 2011 | 01:17 PM
all pm sent
Thanks
Charles
Old Oct 15, 2011 | 03:36 PM
Saturday bump
Charles
Old Oct 20, 2011 | 08:02 AM
bump
Charles
Old Oct 20, 2011 | 01:28 PM
Eishiboy2's Avatar
How much for front and rear camber kits for a 2008 g35 S in either SPC or Ichiba shipped to 90717? Thanks
Old Oct 25, 2011 | 11:54 AM
all pm sent
Thanks
Charles
Old Oct 25, 2011 | 01:04 PM
ThatOneDude's Avatar
Hello,
Price check on front SPC Camber Kit to 98003, please!
Thanks.
