Hotchkis G35 Adjustable Sway Bars!! In Stock and Ready to Ship!!
#106
How much shipped to Toronto Canada m1c1s1. I have a 2007 g35x
Hey guys, we have these Hotchkis Adjustable Sway Bars for 03-06 Sedan and 03-07 Coupe G35's. They are $344.99 shipped anywhere in the US. Simply click on "Add to Cart" to be directly linked to our website so that you can place your order. PM me if you have any questions.
Hotchkis G35 Adjustable Sway Bars 03-06 Sedan, 03-07 Coupe: $344.99 Shipped!
Description: Hotchkis Tuning Sport Sway bars improve your handling and reduce body roll. Turn in with confidence and late brake in the corners with our track tested lightweight hollow sway bars. Sway bar sets include front and rear bars, greasable bushings, and brackets.
Specs:
Front 1 3/8" (35MM) Tubular(Bar Weight 13.5lbs) 4 Position Adjustable
Rear 15/16"(24mm) Tubular(bar weight 5.5lbs) 3 Position Adjustable
Bar Rates:
350Z & 03- 05 G35 Front
Hole 1 = 1525 lbs/in (22% Stiffer than stock)
Hole 2 = 1845 lbs/in (48% Stiffer than stock)
Hole 3 = 2270 lbs/in (82% Stiffer than stock)
Hole 4 = 2855 lbs/in (129% Stiffer than stock)
06 G35 Front
Hole 1 = 1525 lbs/in (5% Softer than stock)
Hole 2 = 1845 lbs/in (15% Stiffer than stock)
Hole 3 = 2270 lbs/in (42% Stiffer than stock)
Hole 4 = 2855 lbs/in (78% Stiffer than stock)
Rear:
Hole 1 = 520 lbs/in (80% Stiffer than stock)
Hole 2 = 655 lbs/in (125% Stiffer than stock)
Hole 3 = 840 lbs/in (185% Stiffer than stock)
Usually Ships in 24 Hours
We are also selling these NEWLY RELEASED Hotchkis Sway Bars:
Hotchkis 22443 Sport Sway Bar Set, G35x 07-08 AWD, G37x 08+ AWD: $394.95 Shipped!
Description: Enhance the cornering performance of your G35X/G37X with a set of Hotchkis Sport Suspension sport sway bars. Our sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the car has slight under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greasable bushings, and brackets
Item# 22443 fits 08+ G35X, G37X AWD Models Only. RWD Models use item 22441
Features:
• Lightweight, Durable 1 3/8" (35mm) Tubular Front Bar.
• Lightweight, Durable 1.125 (28mm) Tubular Rear Bar 3 Way Adjustable
• Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets.
• Finished in durable anthracite powder coat.
Benefits:
• Brings handling excitement to your G35X, and G37X
• Dramatically improves steering and chassis response
• Increases stability, improves traction, reduces body roll by increasing front/rear roll stiffness
• Easy bolt-on installation.
Specs:
Front Sway Bar 35mm (Ø1-3/8") Hollow
+230% Stiffer than Stock G37
+205% Stiffer than stock G37S
+230% Stiffer than stock G37S
Rear Sway Bar 27mm (Ø1.063") Hollow 3 Way Adjustable
+120, 175, 250% Stiffer than Stock G37
+5, 30, 65% Stiffer than stock G37S
+50, 90, 145% Stiffer than stock G35S
Hotchkis 22444 Sport Sway Bar Set, G35x 04-06 AWD: $425 Shipped!
Enhance the cornering performance of your G35X with a set of Hotchkis Sport Suspension sport sway bars. Our sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the car has slight under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greasable bushings, and brackets.
Item# 22444 fits 04-06 AWD G35X models ONLY. RWD Models use item 22441
Features:
Benefits:
Specs:
Specs:
Bar Rates:
06 G35 Front
Rear:
Features:
Benefits:
Specs:
Features:
Benefits:
Specs:
