Xmas Special on Megan Racing Coilovers + Camber Kits !!
Old Dec 23, 2011 | 07:00 AM
mrwong@statik's Avatar
*FREE SHIPPING*
$825 Installed (Coilovers)
+$300 for Front Camber Kit Installed!!
+$150 for Rear Camber Kit Installed!!
Install location is in 91754
Got other coils or a camber kit from somewhere else? Need it installed? Not a problem give me a ring = )
Infiniti G35 / 350z
Model Number : MR-CDK-N3Z
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in **** at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: 10kg Front and 8kg Rear
- 32 Levels of Adjustable Damper
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
-Street Model and Track Model Available.
PM for Best Shipped Pricing!!
Old Dec 31, 2011 | 05:12 AM
pms replied..
Old Feb 15, 2012 | 03:23 PM
I'll keep this deal going until March = )
Old Feb 21, 2012 | 03:54 AM
BigVicG35's Avatar
So it would be $1275 to buy coils, front and rear camber kit which includes install? Which camber kit is this?
Old Feb 21, 2012 | 05:09 AM
pms replied..Special still going on
Old Feb 28, 2012 | 03:51 AM
pms replied..
Old Mar 7, 2012 | 06:30 PM
bloop
Old Mar 8, 2012 | 02:49 PM
sprinkles
Old Mar 8, 2012 | 07:57 PM
bump
Old Mar 13, 2012 | 03:43 PM
g35
Old Mar 14, 2012 | 02:23 PM
Casper101's Avatar
How much for a meagan setup for 08 g35x ?
Old Mar 20, 2012 | 06:26 PM
Statik Performance !!
Old Mar 23, 2012 | 04:58 PM
tgif !!
Old Mar 28, 2012 | 04:47 PM
bump!
Old Apr 3, 2012 | 07:05 PM
bump!!
