TUNERZ STORE | SPC Performance Front & Rear Camber Kits Infiniti G35 &Nissan 350z
Old Jan 5, 2013 | 01:17 AM
Tunerz_Store's Avatar
SPC Camber Kits g35 350z
350Z/G35 FRONT ARMS 72125
Specialty Products' 350Z and G35 Front Upper Control Arms feature:
• More than 20% reduction in unsprung weight over previous designs
• Improved clearance for tight wheel wells and soft springs
• Arm is formed from a single piece of steel rather than welded assemblies
SPC Performance's arm/shim kit is the only one the market to provide a substantial amount of positive camber change. It has more than enough camber and caster change to correct cars that have been lowered, or for vehicles used in drifting. These new arms allow for precise changes when fine tuning suspension alignment angles necessary when racing or drifting. The hub and caliper shims extend out the center of the wheel making it possible for our CNC fabricated arm to make up to 5 degrees total camber change and +/- 1 degree of caster change. Using a sliding and rotating ball joint, techs can fine tune both camber and caster to save tires and improve handling and tire to surface contact. The kit includes everything you need, including the ABS sensor bracket, shims, and arms for both sides of the vehicle.
These arms feature our SpecRide (tm) Jounce Spacers for a quieter, OEM style ride.
Front Adjustment range:
Camber -1.5 degree to +3.5 degree
Caster ±1.0 degree
Installation Time: 1.8 hr/side
Required: 1 kit per axle
REAR CAMBER ARM KIT - 72050 (WITHOUT ACTIVE STEER)
This is the perfect kit for the lowered g35/350z. Provides plenty of adjustment for camber and comes with a larger offset to cam to bring the toe angle back into range.
Rear Adjustment range: Camber +/-3.0 degree Toe +/-2.0 degree
Installation time: .6 hr/side
Required: 1 kit per wheel
**This kit uses a larger cam washer to achieve greater adjustment than the OE toe cam provides. In order to take advantage of full toe adjustment mark the area to elongate the existing toe slot with template provided.**
REAR CAMBER ARM KIT - 72260 (WITH ACTIVE STEER)
Items fit 2003-2007 G35 Coupe and 2003-2006 G35 Sedan, with or without active steer.
PM me for sale prices!
Old Jan 16, 2013 | 01:53 AM
pm me for discounted prices!!
Old Jan 23, 2013 | 10:03 PM
pm me for sale prices!
Old Jan 23, 2013 | 10:50 PM
James86's Avatar
Caster ±1.0 degree
how much
Old Feb 4, 2013 | 02:14 AM
all pm's replied.
In stock ready to ship!
Old Feb 6, 2013 | 02:22 AM
pm me for the best prices!
Old Feb 8, 2013 | 10:56 PM
always great prices!
Old Feb 13, 2013 | 02:23 AM
Thanks for the order!
Old Feb 19, 2013 | 11:54 PM
pm me for a great deal!
Old Feb 27, 2013 | 01:25 PM
locsta's Avatar
How much shipped to 30093 for full kit?
Old Feb 27, 2013 | 04:13 PM
pm sent.
Old Feb 27, 2013 | 06:28 PM
str8upspeed's Avatar
SPC front and rear shipped to 46307 for 04 coupe.
Old Feb 27, 2013 | 06:47 PM
pm sent.
Old Feb 27, 2013 | 10:56 PM
FlyingLumpia's Avatar
spc front for 04 sedan
Old Mar 9, 2013 | 01:50 AM
all pm's replied.
Ask about our package deals!
