ACCUAIR - UAS - K Sport Air - Air Runner - BC Racing - KW ** All Available @ RavSpec
Air System Package
*** Extra $200 Discounts if purchase with WORK/RAYS/WED Wheels ***
Accu Air Management Kit + UAS Bags - $2099 (with Switchspeed non Auto Leveling) or $2899 (with Elevel - Auto Leveling)
Kit Included
- Single Compressor Kit
- E-Level Management provide auto leveling or Swithspeed entry level Air system.
- UAS Universal Air Bags + Brackets
- 5 Gallon Tanks
- All Plumbing Hoses and Fittings
- Power Cables
Order this kit if you already have BC racing, KW, Megan Racing or similar type coil over. UAS bags will replace the existing spring on the coil over.
Kit Included
- BC Racing Coil Over Kit with Built in UAS Bags and brackets
- Non Auto Leveling but switch speed Accu Air Management Kit
- All Plumbings, 5 gallons Tank and One 400c Compressor
- Power Cables
This kit included a full manual switch system from Accu Air for entry level air system. Order this for the most basic entry level air setup from OEM suspension.
Accu Air Management Kit with Auto Leveling + BC Racing Coil Over + UAS Bags - $3699
Kit Included
- Power Cables
Order this kit if you don't have any existing coil over. UAS bags will replace the spring on the BC coil over. This kit will included everything you need for air suspension setup.
Kit Included
- Air Struts (Coil Over + Sleeve Bags)
- Power Cables
Air Struts with sleeve bags (front) built in bags allow for extreme low drop. This kit included everything.
Kit Included
- Air Runner System Included Full Manual Switch, KYB Shocks Built with Air Bags
- Accur Air E Level Management (auto leveling)
- Power Cables
This kit included a full manual switch system in addition to the Accu air E-level auto height adjustment. Air Runner system are built in Japan.
Optional Add On:
- Accu Air eXo Mount Kit provide one simple solution to mount all the accu air modules on the air tank. - $250 Extra
- Additional Compressor (400c) For Faster Up movement and also back up in case first compressor fail. - $199 Extra
- Accu Air Wifi Module, Allow Iphone, Ipad control of the air system - $350 Extra
- E Level (auto leveling) Upgrade from Switch Speed Non Leveling AccuAir System - $980 Extra
Coil Over System Individually
BC Racing Coil Over - BR Series - $1000 Shipped
KW Coil Over - PM For Pricing
Ksport K Control Pro Coil Over - $1000 Shipped
It's a four day job. Yes we can install. Is there a metro train back to Rochester ?
Mark.
Yes there is an amtrak station here lol... but I have a friend in monticello I can stay with or in brooklyn for a couple days... I might have to trailer it to u guys tho cuz its gettin a new paintjob and everything else done to it too...
We will setup the appointment.
Yes it will. If you have the coil over already, just $2899 for the remaining parts to work with the BC coil over.
