TUNERZ STORE | Fortune Auto 500 Series Coilovers Gen 5 - Infiniti G35
Old Jan 31, 2017 | 03:35 PM
Tunerz_Store's Avatar
TUNERZ STORE | Fortune Auto 500 Series Coilovers Gen 6 - Infiniti G35
All Fortune Auto Coilovers are custom built. Please allow 2-3 weeks for shipment.
Available with OEM Rear or True Rear(RWD ONLY).
Fortune Auto engineers were tasked with a focused goal to make the Generation 6 – 500 Series dampers the best single adjustable system on the market at a very affordable price point. All systems are completely built in-house by our engineering staff in Richmond, Virginia. We insist on building bespoke suspension in order to offer the best quality control in the industry.
At Fortune Auto, we approach the science of suspension with a mentality of customization that has raised the industry’s standards of performance.
CUSTOM. MODULAR. REBUILDABLE.
Designed and assembled in the USA.
• FA Synthetic Shock Oil
• Digressive Piston Technology
• Custom Built and Dyno Tested
• 5 Year Limited Manufacturer’s Warranty
• 24-Step Adjustable Dampers
• Monotube Damper with High Pressure Nitrogen
• T6 6061 Aluminum Mounts and Camber Plates
• Rebuildable and Revalveable at our Facility in Richmond, VA
• Modularity – Upgradeable to 2-Way or 3-Way Canister
Everyday Driveability
Research on the racetrack has helped us develop the Fortune Auto 500 Series into a great all-around shock absorber. Using high quality components that meet our strict standards allows us to optimize comfort, reliability, and longevity.
Occasional Track Use
Digressive piston technology allows for stiff low-speed compression/rebound force. This gives more control of driver inputs such as roll, dive, and squat. However, at fast stroke speeds (i.e. high speed bumps) the suspension becomes supple in response to bumps and irregularities in the road for maximum control.
PM me for the best deal!
Old Feb 7, 2017 | 12:05 AM
Gen 6 Coilovers now available...
35% greater range of damping adjustment
Generation 6 models benefit from an upgraded jetting assembly. In previous generations the orifice bleed holes were hand drilled. Generation 6 bleed holes are now CNC machined allowing for more consistent damping adjustments between shocks. Furthermore flow of the orifice bleed holes has increased and a re-designed jetting assembly is used, this yields a 35% increase in damping force adjustment. Providing the user with a shock that has more performance and adjustability.
Revised CNC machined components
New CNC machined adjustment ***** replace the outgoing cast molded *****. These new machined adjustment ***** are hard anodized and more aesthetically pleasing. Updated shaft end caps are now lighter and showcase a more elegant design.
Old Feb 22, 2017 | 12:51 PM
All PM's replied. Thank you for your business everyone. Be sure to check out our other deals and ask us about package deal pricing!
Old Apr 3, 2017 | 05:00 PM
Thanks for the continued support!
Old May 1, 2017 | 11:28 PM
Always great deals!
Old Jun 2, 2017 | 04:12 PM
Old Jul 6, 2017 | 10:59 AM
PM me for your best deal!
Old Aug 22, 2017 | 07:19 PM
Old Sep 30, 2017 | 03:12 PM
