V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Installed Stillen Gen3
Old Feb 10, 2009 | 10:20 PM
mishmosh's Avatar
I actually got the Stillen intake a couple of weeks ago, but put off installing it because I was so excited to get the Hotchkis sway bars on. Well I had some time yesterday so on it went. Let's just say the install was a bear--just as has been reported!
Removing stock intake - easy. Removing radiator cover and grille - easy. Enlarging core support holes - easy. Hooking up the intake so it doesn't rub - so NOT easy! I spent a long while trying different ways to make the pipe fit without rubbing. I finally think I got it to where it is the best it can be. The problem is that the metal behind the core support only allows for a small amount of movement of the pipe before rubbing occurs. I finally got it to a few mm's away--but put rubber hose in the gap just in case.
Here's the final installed pic:
Youtube Install video (overview):
Some other pics:
Core support holes after enlargement. I used a SoniCrafter (oscillating tool) which cut through the plastic like butter!
These are the core support holes before cutting.
You need to watch out for all that A/C line on the drivers side. I wrapped some of it with the hose per Stillens instructions, because of contact.
Here is a shot of the metal in back of the core support. It is strong metal and i did not want to cut it to make the opening bigger. Ended up putting rubber hose in the gap.
Filter pic. I attached the shield to the driver's side filter (instead of the passenger side per Stillens instructions). The center bar was in the way on the passenger side. Accordingly, I swapped filters (passenger side bolt is longer to accommodate the shield.
For those who expect perfection, the fitment isn't--and not for lack of trying. Still, I am satisfied the the install.
Sound is great--but not unlike other similar types of intakes. Loud when you get on it but quiet otherwise. Can't tell much in terms of performance just yet--too easy for my winter tires to break free! I do love how it looks in the engine bay though!
Old Feb 10, 2009 | 10:32 PM
earth0's Avatar
Nice DIY! and detail bro. If you can tell the performance would be great.
Have reset the ECU? Recommended BTW!!!
Old Feb 11, 2009 | 01:33 AM
G35driver101's Avatar
Nice writeup. This install is a pita. I removed a bit more of the core support just encase. I dont want to have to redo it down the road!
Old Feb 11, 2009 | 03:05 AM
Defratos's Avatar
You're Despicable
Very nice write up mate, really appreciate the pics you've posted because its the first time I can actually tell what everyone's been going on about cutting things out of the car. Hope you enjoy the new toys
Old Feb 11, 2009 | 05:59 AM
meladh229's Avatar
very very nice man i want to get one now lol nice job
Old Feb 11, 2009 | 07:46 AM
mishmosh's Avatar
Thanks everyone. This is not really a DIY writeup...just sharing my experience with the install.
FYI, you do not necessarily need to remove the bumper cover (fascia). However, when inserting the end tube on the drivers side, part of the tube scrapes metal as it goes in--kind of in the middle of the tube--will probably polish it out. Other than that, there should be enough room to work. Also, I enlarged the core support holes more than I needed to in retrospect. The limiting factor for fitment is not the core support but the metal behind it. Still, I don't think it hurts to make the openings a little larger so when it comes to wrangling the pipes in various positions, you can be assured that the core support is not the problem.
Old Feb 11, 2009 | 10:02 AM
ANMVQ's Avatar
Nice job man, Great song BTW.. LOL I enjoyed the vid..
Old Feb 12, 2009 | 06:58 AM
G35Robby's Avatar
I love the vid
That'll help me out when i put mine on lol
Congrats, enjoy the new intakes
Old Feb 16, 2009 | 03:58 AM
popcornten's Avatar
gah I wish I was handy
do you think this is too difficult for someone without much experience? the video (which is amazing) doesnt seem all that difficult, but you say there was a lot of issues with fitment and rubbing?
I was looking at the K&N, but the huge claimed performance for these from Stillen seems more than worth the extra price - but I'd like to just intall myself.... insights?
Old Feb 16, 2009 | 04:05 AM
G35Robby's Avatar
If you at least know someone with a bit of experience to help you out, you should be fine.
Old Feb 16, 2009 | 06:18 AM
mishmosh's Avatar
Technically, the install is not difficult, BUT you will probably spend a lot of time fiddling with slight pipe twists and turns trying to get the setup not to rub. Unfortunately, you can try and try and it will never be perfect--but you almost need to convince yourself this by trying the different configurations. I wish the filter bracket was a little longer from center bracket to the front and could be height adjusted--that would have helped with fitment a lot.
Old Feb 16, 2009 | 04:20 PM
DrGeeMD's Avatar
yes, thanks for the write-up and pics. Much appreciated.
Old Feb 21, 2009 | 11:29 PM
95 maxima se's Avatar
sweet now i wanna buy stillen intake
Old Feb 23, 2009 | 08:52 PM
Q8y_drifter's Avatar
me too ^^
Old Jan 9, 2011 | 06:48 PM
djfarhan's Avatar
how r the splas guards holding up man?
