V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
I spent the day installing Signal mirrors on my Sedan.
Old Apr 19, 2008 | 07:47 PM
Replayray's Avatar
First of all, don't flame me for not posting pictures. I am running late so I will post them later.
It is Saturday and I finished the installation for the LED Signal mirrors. It was suggested that there might be wires for side markers under the fender liners. There aren't any wires under the fender liner. I removed the front left wheel and liner and no side marker wires or even a harness to the front. The wiring harness runs across the top of the engine compartment.
I finally decided that the rear of the car was easier to get to than the front and firewall. I removed the trunk liner and ran both the ground and signal wires from each rear blinker from the trunk to the firewall area. It was by far the easiest path. Funny thing, the rear blinkers have their own ground and not a shared chasis ground. I determined this with my 12 volt test light. It would not light up on the hot signal when the test light was grounded. My only solution was to run both signal and its ground up to my mirrors. It worked great!
There is an easy path under the door sills but I had to remove the rear seat to run my wires.
Once I got the signal and ground to the door hinge, I drilled a small hole from the kick panel through the body to the door hinge. I then removed the door panels and speaker and ran the wiring up to just below the mirror. I took the mirror off the door and ran the wires up inside. Using the same path as the remote for the mirror.
The mirrors just snap in place of the original mirror covers.
It took almost 6 hours but I could do the next set in 2-3 hours from what I learned.
__________________
Old Apr 19, 2008 | 07:52 PM
Beebo's Avatar
cant wait for pics... you should make a DIY
Old Apr 20, 2008 | 12:49 AM
hullio's Avatar
Pics pics pics!
Old Apr 20, 2008 | 02:35 AM
johnnyzee's Avatar
Old Apr 20, 2008 | 02:48 PM
g35_6gear's Avatar
Originally Posted by johnnyzee
Give it a rest...he said he would post pics later.
Old Apr 20, 2008 | 03:13 PM
FlSHRFun's Avatar
Hah-hah-hah-hah-hah!
Great job on being the first (07 sedan)!
Old Apr 20, 2008 | 06:39 PM
Replayray's Avatar
My first attempt to post pics of my signal mirror installed
I will get them painted later next week. It only takes a few seconds to remove them and put the original covers back on.
Attached Thumbnails I spent the day installing Signal mirrors on my Sedan.-scaled2.jpg   I spent the day installing Signal mirrors on my Sedan.-scaled-mirror.jpg
Old Apr 20, 2008 | 07:00 PM
Replayray's Avatar
More pics
More pics
Attached Thumbnails I spent the day installing Signal mirrors on my Sedan.-255k.jpg   I spent the day installing Signal mirrors on my Sedan.-264k.jpg   I spent the day installing Signal mirrors on my Sedan.-266k.jpg
Old Apr 20, 2008 | 07:10 PM
Replayray's Avatar
I found them on ebay
Here is the link for them on ebay
http://cgi.ebay.com/ebaymotors/07-08...4513QQtcZphoto
Old Apr 20, 2008 | 07:31 PM
rpm&my_G35's Avatar
Those will look very nice!
Just to be silly, you should tell your insurance co. Doesn't this technically make your car safer? If they where OEM and you where to remove them they would probably raise your rate so by adding them, arguably as safety feature, they should lower it. You know what?..., they would probably give you heck for modifying it. lol
Just enjoy the look!
Old Apr 20, 2008 | 07:50 PM
SVLRx's Avatar
humm, put some kind of water mark on the pic.... I've seen so many times someone is first at putting something on their car, and then someone steals the pic to use in their ebay auction..... oh yea, looking good BTW
Old Apr 20, 2008 | 07:53 PM
Beebo's Avatar
^+1
Old Apr 21, 2008 | 02:34 AM
johnnyzee's Avatar
I know I know, I just like bustin' chops!
__
Otherwise, looks awesome man! Making me want to do a spring project myself
Old Apr 21, 2008 | 11:05 PM
FlSHRFun's Avatar
Great job! Wonder if you could put these on first generation sedans.
Old Jun 19, 2008 | 09:13 AM
johnegq's Avatar
I love the car color, spoiler, and other option choices (we have very similar cars). Painted the side mirrors yet? I would love to see more pictures with the matching paint.
Any pics of your grill installed? I'm also interested.
GOOD WORK!!!
