TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
anyone ever have a problem with Tranny/syncros?
Old Jul 3, 2006 | 11:32 AM
G-MAN (CANADA)'s Avatar
Question anyone ever have a problem with Tranny/syncros?
My tranny in my G sedan has always been a little clunky sepecialy going into second gear, the other day I was driving to work I pushed it off the light and misshifted into second gear since then I can't shift quick into second without grinding (most of the time). It wasn't smooth before but now its a little worse the car is still under warranty but I'm not sure how to approach them with my problem, if I swich slow into second at high rpm's it won't grind but if I switch quick enough to chirp second most likely it will grind. Have any of you brought your car to the dealer with this problem? will they cover a syncro problem?
Old Jul 3, 2006 | 11:56 AM
Texasscout's Avatar
You need to have it checked. You should be able to shift without grinding. A few times my third sync has felt a tooth or two, but not very often. I have 32K on it so far.
Old Jul 3, 2006 | 12:07 PM
UFGatorG35's Avatar
My 04 coupe made a grinding noise going into 5th and 6th, and it was the TSB problem. They replaced the tranny that week and everything was great afterwards. I would def take it in.
bananax
Sep 24, 2019 12:24 PM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
