TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
window problems
Old Oct 5, 2007 | 10:56 AM
mastamug's Avatar
window problems
Hello..
I have a 2003 infiniti g35 coupe. I know many of you have problems with windows. My problem is not the window going up and down, it is sometimes the car doors do not lock. Also when I have the window rolled DOWN all the way on the passenger side it sounds like the glass is smacking back and fourth or something is loose. I also have a problem with my seat it seems the whole base is loose and the whole thing jut tilts back and fourth. If anyone has any feed back please let me know. I am also out of warranty as of May of this year.
Old Oct 5, 2007 | 11:48 AM
Hi-TechG35's Avatar
The window problem is either one of two things and that is the motor or the regulator. If your window goes up and comes back down 1/4 of the way you will have to get adjusted. If it goes down and won't go back up you have to change the regulator. PM Jason@Riverside for the parts. he will hook you up. As far as the seat I don't know what more to tell you than try to see if you can locate the problem tighten it up or fix the seat.
Old Oct 22, 2007 | 09:58 PM
Gdrive's Avatar
Thats not true either, I had a friend who is a mechanic for Nissan, replace the regulator and motor, and same thing happening, checked all ground wires,there was a loose one.
Old Oct 29, 2007 | 08:53 AM
giddyup69's Avatar
there is a tsb for the seat. i had a similar problem with mine. it would shift a little and click when accelerating and braking.
_______________________________
ITB02-080d
2003-2006 INFINITI G35 SEDAN AND 2003 - 2007 G35 COUPE; DRIVER’S SEAT NOISE AND/OR ROCKS BACK AND FORTH
The driver’s seat cushion feels loose;
• “Rocks” back and forth and/or makes a “pop”, “click”, “creak” or “clunk” noise.
• If it occurs, it usually happens when the vehicle accelerates from a stop or when making a turn.
mike730
Jan 12, 2018 04:25 PM
leo38cheng
Nov 12, 2015 06:49 PM
cmesidewayz
Sep 29, 2015 09:28 PM
gatorglaze
Sep 10, 2015 12:03 PM
Jnm07
Sep 5, 2015 01:16 AM
