TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
clutch stuck tsb?
Old Dec 19, 2008 | 03:59 AM
ac419's Avatar
clutch stuck tsb?
hi everyone,
anyone know if there's a tsb for a stuck clutch. i know the dealership will ask to replicate the problem.. but it only happens every so often. how can i get this problem fixed? thanks.
Old Dec 19, 2008 | 06:04 PM
G35guy's Avatar
I'm having the same problem. Only happens once in a while. Anyone have answers?? Thanks.
Old Dec 20, 2008 | 12:11 AM
escobar929's Avatar
most likely its the master cylinder, i have the same problem
Old Dec 21, 2008 | 05:25 PM
05350GT6MT's Avatar
happens every one in a while for me also
Old Dec 21, 2008 | 05:27 PM
patman530's Avatar
have you tried flushing out the clutch fluid?
Old Dec 22, 2008 | 07:39 AM
fbpem1's Avatar
3 things it could be, clutch slave, clutch master, and the actual belleville spring in the disc, i have seen all 3 do this with the clutch master cylinder being the most rare only 2 occasions out of the 50+ times i have seen this.
Flushing the fluid to a dot 4 or higher will be a temporary fix.
Old Jan 12, 2009 | 05:11 PM
Ashyknucklz's Avatar
Ok, so what exactly happens when the clutch sticks? My car has been acting kinda funky rcently......
Old Jan 12, 2009 | 06:05 PM
ac419's Avatar
i just took it into my dealership and they replaced the clutch master cylinder, luckily it was under warranty
Old Jan 12, 2009 | 07:40 PM
Rallycraft's Avatar
To clear up the original question, no there is no bulletin for a stuck clutch. Glad to hear they replaced your problem
Old Feb 3, 2009 | 12:38 AM
Deepdiver's Avatar
did they replicate the problem or did they take your word for it?
Old Feb 3, 2009 | 12:32 PM
ac419's Avatar
they just took my word for it
Old Feb 4, 2009 | 01:04 AM
sessman's Avatar
hmm
Old Feb 4, 2009 | 01:15 AM
ac419's Avatar
dont let this to be the reason for not buying the G. it's a small part only some cars have encountered this problem. some say the master cylinder some say it's air bubbles in the thing.. the G is still a great car
Old Feb 4, 2009 | 12:10 PM
ResIpsa's Avatar
Before you do anything else, flush of your hydraulic clutch fluid. It is easy and cheap. Here is the link.
http://www.rangeracceleration.com/Clutch_Care.html
I know this seems almost too easy to be true. Trust me, I had my dealer check out the problem and they are clueless. They did a so called "clutch adjustment" that did absolutely nothing.
I was in the process of pricing out a new clutch and Fly Wheel when I came across the above thread. For the hell of it I tried it, and the problem was instantly cured. And that was 40,000 miles ago.
Now I flush my fluid twice a year just to be safe.
Let me know how it works.
Old Feb 4, 2009 | 12:18 PM
Yv12345vY's Avatar
^ Very interesting, I'll have to check this out.
