TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
No power to trunk release or glove compartment
Old Mar 29, 2009 | 04:52 PM
donr's Avatar
I cannot open my truk and when I checked for power there is no power to the trunk release and there is no power to the valet switch in the glove compartment. no light in the glove compartment either. Checked fuses but don't know which is for trunk and glove.
Old Mar 29, 2009 | 04:56 PM
Beebo's Avatar
you will get more responces if you post your question in the G35 Coupe section of the forum, or ask a mod to move this thread.
as for your question im not sure
Old Mar 29, 2009 | 04:58 PM
donr's Avatar
no electric power to trunk release
No power to the vanity switch in the glove compartment or trunk release. No power to light in glove compartment. Anyone know which fuse controls these?
Old Mar 23, 2010 | 02:02 AM
SteveZ's Avatar
Besides a fuse this can also be caused by the wire breaking in the bundle that goes from the trunk to the chassis. Seems all that flexing opening and closing the trunk on some wire assemblies has caused problems, they are a spec item sub-contracted and so there have been quality variations. Too short wiring (ever so slightly) is one issue.
My rear brake wing mount light shorted out like this and sent the braking system into limp mode. the wire broken was very hard to find. I can see why with the circuit broken you're not going to get power up front on the switch (the release) since the circuit may be shorted out.
I have the trunk actuator release not working on my '04, just popped up this month and now have to deal with that, same sort of problem and betting my wiring is messed up in the same general area
Old Mar 23, 2010 | 02:59 AM
340tog35's Avatar
YOOOOooooooooo homieeeeeeeeee its time for you to get in to the zone Auto Zone
Old Mar 24, 2010 | 08:11 AM
SteveZ's Avatar
Extraordinarily Un-helpful.
If the issue was as simple as a fuse, it would be done. Have you ever tried to trace a break in a wire for any of the systems running through the rocker panel, back to the trunk area?
Thought so.
Old Mar 30, 2010 | 11:22 AM
Mark7's Avatar
Try using a multi-meter looking for Voltage Drop Method. Put one end (RED) at a known power source in that wire and the negitive on the same wire at the next junction. You will read 12 Volts up till the break. This will islolate the section that the break is in. Very simlar to Contiunity but with 12 volt DC setting.
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
zcherub
Sep 10, 2015 12:03 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
johnadlertech
Interior
Sep 4, 2015 12:26 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
