TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Slight Oil In #6 Spark Plug Tube ... Should I Be Concerned?
Old Jan 13, 2012 | 07:51 PM
2_Liter_Turbo's Avatar
Exclamation Slight Oil In #6 Spark Plug Tube ... Should I Be Concerned?
I went to check the condition of my plugs, and found that the #6 spark plug tube had a little oil at the top on the seal (see pictures). The tube itself was dry, but the plug smelled a little of oil and looked as pictured below. All 5 other ones were completely dry. Is this the start of an "oil consumption" issue? Or is it under a different TSB (If so, is there a link?)? Also, at it's current state, will Infiniti warranty it, or am I going to have to pay to get the valve cover replaced? I looked around, but couldn't find the post I originally saw about the #6 coil being covered in Oil, lol. Any input would greatly be appreciated!
Now for some pics:
Old Feb 27, 2012 | 11:26 AM
Manhattan Project G's Avatar
here you go! g35driver.com/forums/engine-drivetrain-forced-induction/241910-check-before-your-powertrain-warranty-up.html
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
JoeMac
Aug 20, 2015 10:17 AM
yassy
Aug 9, 2015 07:31 PM
wuppiedog
Aug 7, 2015 11:16 AM
ghost_g35
Aug 7, 2015 10:31 AM
