TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Complete list of TSB's
Old Jun 7, 2003 | 08:43 AM
BillR's Avatar
Thanks to PROfusioNZ from FA!!
Complete List of TSBS for G35 Coupe and Sedan -- Last Updated 6/6
Service Bulletin Num : 03033 Date of Bulletin: ?
Type: Sedan
Component: AUTOMATIC TRAN./TRANSAXLE (AT)
Summary:
Reverse to Drive Engagement Delay/Shock
IF YOU CONFIRM:
The transmission in an applied vehicle has delayed engagement and/or "shift shock" when shifting into Drive ("D") range from Reverse ("R").
ACTION:
Follow the "Diagnosis and Repair Flow Chart" (page 2) to resolve the incident.
Service Bulletin Num : 03028 Date of Bulletin: ?
Type: Coupe
Component: FRONT AXLE/SUSPENSION
Summary: Steering Drift to the Right
IF YOU CONFIRM: The vehicle has a tendency for a constant drift to the right on a straight, flat road at highway speeds. NOTE: A vehicle is said to drift, if The vehicle completes a lane change in less than 7 seconds and with no steering correctionfrom the driver and when driving at 60 mph and all four wheels must pass into the other lane during this time (7 seconds) and while driving on a crown-sloped road of less than 1 percent.
ACTIONS: Verify the incident drift as described above. Install the right front suspension compression rod from the Parts Information section of this bulletin.
Service Bulletin Num : 03021 Date of Bulletin: ?
Type: Coupe
Component: Body Trim
Summary: Grease Mark Or Streak On Inside Of Door Glass
IF YOU CONFIRM: A mark or streak of grease on the inside of the door glass after the window has been lowered and then raised.
ACTIONS: Remove the door window regulator module assembly. Replace the original glass "stabilizer" felt with the new pieces from the Stopper Kit.
Service Bulletin Num : 03020 Date of Bulletin: ?
Type: Coupe
Component: ENGINE CONTROL SYSTEM
Summary: MIL 'ON' DTC P0442 and/or P0456 Stored
If: an Applied 2003 G35 Coupe or FX45 has a MIL "On" and has one or both of the following DTCs stored in the ECM: - P0442 EVAP Small Leak - P0456 EVAP Very Small Leak Start with the SERVICE PROCEDURE to find out if this bulletin applies to this vehicle. If it does apply, complete the Service Procedure to repair the incident, if it should occur. See this bulletin for further detail.
Service Bulletin Num : 03023 Date of Bulletin: APR 04, 2003
Type: Coupe
Component: STRUCTURE:FRAME AND MEMBERS
Summary: RATTLE FROM THE REAR PARCEL SHELF. *SCC
IF YOU CONFIRM: A rattle noise is heard from the rear parcel shelf: • While driving on rough roads, or • When the audio system is played,
ACTIONS: Apply felt cloth tape to the center clips that hold the rear parcel shelf in place. •Attach a self adhesive urethane pad over the harness connector located under the rear parcel shelf.
Service Bulletin Num : 03017 Date of Bulletin: MAR 12, 2003
Type: Sedan
Summary: REAR PARCEL SHELF BUZZ OR RATTLE. *SCC
IF YOU CONFIRM: An applied G35 Sedan has a buzz or rattle noise from the rear parcel shelf area under the following conditions: - when the audio system is used with low frequency (high bass) audio, OR - when driving over bumps. See thisbulletin for further detail.
Service Bulletin Num : 03018 Date of Bulletin: MAR 12, 2003
Type: Coupe and Sedan
Component: SEATS
Summary: DRIVER'S SEAT COMFORT IMPROVEMENT. *SCC
IF YOU CONFIRM: The power seat switch is causing discomfort to the vehicle driver,
ACTIONS: Remove the plastic support plate from the power seat switch bracket. - Install urethane foam pad behind the power seat switch bracket.
Service Bulletin Num : 03014 Date of Bulletin: FEB 19, 2003
Component: ELECTRICAL SYSTEM
Summary: SLIP AND VDC OFF LIGHTS ON WITH C1145 YAW RATE SENSOR STORED. *SCC
IF YOU CONFIRM: An applied 2003 G35 Sedan shows the following symptoms: • "SLIP" and "VDC OFF" lights on the instrument panel are or were "ON" AND • In the ABS "Self-Diagnosis Results" (using CONSULT-II) the code: "Yaw rate sensor" (C1145)is stored.
Action: Perform the Service Procedure provided in this bulletin.
Service Bulletin Num : 03013 Date of Bulletin: ?
Type: Sedan
Summary: WINDSHIELD WIPERS NOISY
IF YOU CONFIRM: An applied vehicle shows the following symptom: • The windshield wipers skip and make a "judder" noise as they sweep across the windshield,
ACTIONS: Verify the incident noise as described. • Determine Vehicle's Applied VIN and Date. Complete Repair Procedure as noted: - Vehicles built AFTER Applied VIN and Date shown in this bulletin - Replace Wiper Blade Assemblies. - Vehicles built BEFORE Applied VIN and Date shown in this bulletin - Install Washer under WiperMotor Mount and Replace Wiper Blade Assemblies.
Service Bulletin Num : ITB03007 Date of Bulletin: FEB 13, 2003
Type:
Summary: VOLUNTARY SERVICE CAMPAIGN AUDIO FINISHER CIRCUIT BOARD. *JB
Service Bulletin Num : 03006 Date of Bulletin: JAN 29, 2003
Component: SERVICE BRAKES, HYDRAULIC
Summary: REAR BRAKE NOISE. *TT
IF YOU CONFIRM: An applied vehicle shows the following symptoms when braking: • a "squeak" or "squeal" noise coming from the rear brakes, • after the brakes have warmed up (to operating temperature), • mostly when braking during "stop and go" or mountain driving conditions.
ACTIONS: Remove and Replace the Rear Brake Pads with the ones from the PARTS INFORMATION section of this bulletin.
Service Bulletin Num : 03004 Date of Bulletin: JAN 17, 2003
Type: Sedan
Component: STRUCTURE:BODY:ROOF AND PILLARS
Summary: HEADLINER SAGGING AT REAR OF SUNROOF. *TT
IF YOU CONFIRM: The "headlining"(headliner) on an applied vehicle is sagging (loose) at the rear of the sunroof opening,
DETERMINE IF: The headliner edge is back slightly from the rear edge of the sunroof opening
ACTION: If the headliner is back slightly, follow the steps in the Service Procedure to move the sunroof assembly back (rearward) about 1/8 inch (4 mm).
Service Bulletin Num : 03003 Date of Bulletin: JAN 13, 2003
Type: Coupe
Component: POWER TRAIN:MANUAL TRANSMISSION
Summary: MANUAL TRANSMISSION SHIFT **** NOT STRAIGHT. *TT
IF YOU CONFIRM: The manual shift lever **** on a 2003 G35 Coupe: • is not straight (is off-center or slanted). ACTIONS: You will be replacing a rubber bushing under the shift lever threads. Use the Service Procedure provided in this bulletinto repair the incident, if it should occur.
Service Bulletin Num : 03001 Date of Bulletin: JAN 16, 2003
Type: Sedan
Component: EXTERIOR LIGHTING:HEADLIGHTS
Summary: VOLUNTARY RECALL CAMPAIGN - HEADLAMP ADJUSTER CAP INSTALLATION. *TT
In order to meet Safety Standard 108, tamperproof caps are installed at the factory on the horizontal adjustment device of the headlamp assemblies. This is to prevent misadjustment of the headlamps. These tamperproof caps were mistakenly omitted on theaffected vehicles. Therefore Nissan has determined that the headlamp assemblies on some 2003 model year Infiniti G35 sedan vehicles fail to comply with Federal Motor Vehicle Safety Standard 108 - Lamps, Reflective Devices, and Associated Equipment.
Service Bulletin Num : 02081 Date of Bulletin: DEC 19, 2002
Component: INTERIOR LIGHTING
Summary: INTERIOR COURTESTY LAMPS INOPERATIVE. *TT
IF YOU CONFIRM: The interior "courtesy lamps" are inoperative on an applied vehicle, NOTE: Courtesy lamps include map/dome, step, vanity, personal, and ignition key hole illumination. DETERMINE IF: The Body Control Module (BCM) needs to be replaced. ACTIONS: • Follow the service procedure in this bulletin (on page 2) to diagnose the incident. • If necessary, replace the BCM with the part number listed in the Parts Information. NOTE: Before starting this Service Procedure, collect all vehicle keys and remote controls from the customer. If BCM replacement is needed, all the vehicle keys and remotes will need to be programmed into the new BCM.
Service Bulletin Num : ITB02080 Date of Bulletin: ?
Component: DRIVER SEAT
Summary: DRIVER SEAT ROCKS
IF YOU CONFIRM: The driver seat cushion feels loose; • "Rocks" back and forth and/or makes a "pop" / "click" noise. • Usually when the vehicle accelerates from a stop or when making a turn.
Action: Replace the front Seat Lifter Link Bracket Assembly with a new one-P/N 87463-AM501.
Service Bulletin Num : ITB02079 Date of Bulletin: ?
Type: Sedan
Component: INTERIOR/CLOCK
Summary: CLOCK HARD TO READ AT NIGHT
IF YOU CONFIRM: A 2003 G35 Sedan has the following symptom; • The clock is difficult for the customer to see at night.
ACTIONS: Verify the incident as described above. • Use the Service Procedure in this Bulletin to replace the original clock with the clock listed in the Parts Information section of this Bulletin.
Service Bulletin Num : 02078 Date of Bulletin: ?
Type: Coupe
Component: INOPERATIVE WALK-IN LEVER
Summary: PASSENGER SIDE SEAT WALK-IN LEVER DOES NOT WORK
IF YOU CONFIRM: The Walk-in Lever on the back of the right front seat (front passenger's seat) does not work,
DETERMINE IF: The Walk-in Control Cable has come loose from the Walk-in Lever.
Service Bulletin Num : 02074 Date of Bulletin: DEC 03, 2002
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary: AUTOMATIC TRANSMISSION HARSH SHIFT WITH DIAGNOSTIC TROUBLE CODE P1710 AND P1716 STORED. *TT
If: an applied 2003 G35 has a harsh or erratic shift from the Automatic Transmission after it is warmed up, use this bulletin to determine if the Transmission Control Module (TCM) needs to be replaced.
Service Bulletin Num : 02073 Date of Bulletin: NOV 19, 2002
Component: WHEELS
Summary: TITANIUM FINISH ALUMINUM WHEELS. *TT
When cleaning titanium finish aluminum wheels: • ONLY use aluminum wheel cleaner • Do NOT use chrome or wire wheel cleaners as surface discoloration may occur (e.g., black stains or spots)
Service Bulletin Num : 02072 Date of Bulletin: NOV 08, 2002
Component: EQUIPMENT:ELECTRICAL
Summary: AMBIENT TEMPERATURE SENSOR DISPLAY INACCURATE. *TT
If a 2003 G35 ambient temperature (outside temperature) display shows a temperature higher than the actual outside temperature when all of the following conditions are met: • The vehicle has been driven so the engine is up to full operating temperature, then • The engine is stopped. • The engine is then restarted before it has completely cooled. Use the Service Procedure to install the "Sen Assy-Ambient, Bracket Kit" listed in the Parts Information of this bulletin.
Service Bulletin Num : 02067 Date of Bulletin: OCT 29, 2002
Type: Sedan
Component: SEAT BELTS:FRONT:BUCKLE ASSEMBLY
Summary: FRONT SEAT BELT BUCKLE BRACKET CAUSING CLICKING NOISE. *TT
If: an Applied 2003 G35 Sedan has the following symptom: • a clicking noise heard in the front driver's and/or front passenger seat belt buckle bracket, use the Service Procedure in this bulletin to resolve the incident, if it should occur.
Service Bulletin Num : 02064 Date of Bulletin: OCT 01, 2002
Summary: REPLACEMENT AUTOMATIC TRANSMISSION REQUESTS NEW STYLE AUTOMATIC TRANSMISSION FLUID FILLER TUBE. *TT
If: the automatic transmission on an applied vehicle requires replacement, • A new-style ATF filler tube must be installed with the new transmission. • The ATF filler tube from the old transmission will not fit onto the new transmission. (The transmission case has been changed slightly).
Service Bulletin Num : 02062 Date of Bulletin: OCT 01, 2002
Component: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC.
Summary: AUDIO MATRIX. *TT
When replacing the audio unit and/or audio finisher for a 2003 or 2003.5 G35 Sedan or a 2003 G35 Coupe, this bulletin provides the following information - • Replacement Part Numbers for Audio Units. • Replacement Part Numbers for the Audio FinisherONLY. Refer to the tables and information provided in this bulletin for details.
Service Bulletin Num : 02060 Date of Bulletin: SEP 26, 2002
Type: Sedan
Summary: CREAK NOISE FROM FRONT END. *TT
If: an applied vehicle has a creak noise coming from the front end when it is driven under the following "body-twisting" conditions: • Road dips • Rain channels • Street intersections • Driveways Use the Service Procedure on page 2 to resolve theincident, if it should occur.
Service Bulletin Num : ITB02058 Date of Bulletin: ?
Type: Sedan
Component: ACCEL.CONTRL, FUEL & EXHAUST SYS. (FE)
Summary: Fuel Hose Connection Recall Campaign
Nissan Motor Company, Ltd. has determined that on some 2003 model year Infiniti G35 sedan vehicles, there is a possibility that the fuel hose connection from the fuel pump may not have been properly attached when the vehicle was produced and could come loose while driving or when starting the engine. If the connection comes loose while driving, the engine will stop running due to lack of fuel. If the engine stops running while driving, this could result in a crash. Also, if the connection comes loosewhile driving or attempting to start or restart the engine, some fuel will discharge from the fuel pump. If this should occur in the presence of an external ignition source, a fire could result. To prevent this condition from occurring, Infiniti is conducting a Voluntary Safety Recall Campaign to inspect and, if necessary, properly attach the fuel hose to the fuel pump.
Service Bulletin Num : 02057 Date of Bulletin: SEP 18, 2002
Component: STRUCTURE:BODYOOR
Summary: POP OR CLUNK NOISE FROM FRONT DOOR AND / OR WINDOW. *TT
If: the front driver's or passenger door and/or window has: • a pop noise when the windows are operated UP or DOWN, OR • a clunk noise when windows reach full UP or DOWN position,
Action: Check to see if the noise is coming from the window regulator attachment bolts. If it is, tighten the bolts as described in the Service Procedure in this bulletin to repair this incident, if it should occur.
Service Bulletin Num : 02056 Date of Bulletin: OCT 01, 2002
Type: Sedan
Component: EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Summary: BUZZ OR GROWL TYPE NOISE FROM ENGINE AREA WITH AIR CONDITIONER ON. *TT
If a 2003 G35 Sedan has: a buzz or growl type noise from the engine area with the Air Conditioner "ON," which goes away when the Air Conditioner is turned "OFF," Refer to the Service Procedure in this bulletin to help identify if the noise is coming from the A/C system. If it is, install the Air Conditioner Kit parts to complete the Service Procedure and reduce the noise, if it should occur.
Service Bulletin Num : ITB02055 Date of Bulletin: OCT 01, 2002
Type: Coupe
Component: ELECTRICAL SYSTEM:BATTERY
Summary: INFORMATION ON COUPE BATTERY SERVICE PRECAUTIONS. *TT
If: the battery of a G35 Coupe is disconnected while: • the doors are closed and • the windows are in the fully raised position The top edge of the windows may hang up on the edge of the roof, when the doors are opened or closed. This could damagethe window, roof, or door glass run rubbers. This car has a feature that lowers the window about 10 mm when the door is opened. This feature also raises the window about 10 mm to a "fully raised" position when the door is shut. This is to reduce wind noise and decrease door-closing effort. To help prevent damage to the window, roof, or door glass run rubbers during battery-related service, see the Service Procedure in this bulletin for steps to take before: • performing battery service, or • performing any service that requires disconnecting the vehicle's battery.
Service Bulletin Num : 02054 Date of Bulletin: SEP 12, 2002
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary: MALFUNCTION INDICATOR LIGHT (MIL) ON WITH DIAGNOSTIC TROUBLE CODE (DTC) P0442 (EVAP SMALL LEAK) STORED IN THE ELECTRONIC CONTROL MODULE (ECM). *TT .
If: an Applied 2003 G35 Sedan has a MIL "On" and the following DTC stored in the ECM: • P0442 EVAP Control System (EVAP Small Leak) Start with the SERVICE PROCEDURE to find out if the bulletin applies to this vehicle. If it does apply, complete theService Procedure to repair the incident, if it should occur.
Service Bulletin Num : ITB02028 Date of Bulletin: SEP 18, 2002
Component: VISIBILITY:WINDSHIELD
Summary: INFORMATION PERTAINING TO A SQUEAK, CREAK, OR RATTLE NOISE COMING FROM THE CENTER OF THE DASH OR BOTTOM OF THE WINDSHIELD WHILE DRIVING. *TT
If: a 2003 G35 (V35) has a squeak, creak, or rattle noise coming from the center of the dash or bottom of the windshield while driving, Determine if the source of the noise is from the attaching points for the "Cowl". Use the Service Procedure in this bulletin to diagnosis and repair the incident if it should occur.
Service Bulletin Num : ITB02021 Date of Bulletin: JUL 30, 2002
Summary: CONCERNS WITH RATTLE OR BUZZ NOISE FROM FRONT DOOR PANEL(S). *TT
If: a 2003 G35 has a rattle or buzz noise coming from the front door area(s) when: • listening to the audio system with a volume setting of "15" or below and/or • when driving over rough surfaces, Refer to the Service Procedure listed below to resolve the incident, should it occur.
Service Bulletin Num : ITB02019 Date of Bulletin: APR 03, 2002
Summary: CONCERNS WITH TACHOMETER NEEDLE ON WRONG SIDE OF STOP PIN. *TT
If: an Applied Vehicle displays the following symptom - - The Tachometer Needle is on the wrong side of the stop pin, DO NOT replace the Tachometer. The incident can generally only occur if the storage fuse has been removed, and the ignition key is turned OFF while the engine is operating over 4500 RPM. Therefore, this situation is most likely to occur after the vehicle leaves the factory, but before the dealer performs the Pre-Delivery Inspection (PDI). Please perform the System Information Reset Procedure provided in this bulletin before deciding if any additional repairs are needed.
Service Bulletin Num : ITB02017 Date of Bulletin: APR 01, 2002
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary: SUBJECT REGRDING TRANSMISSION CONTROL MODULE (TCM) INITIALIZATION AFTER TRANSMISSION REPLACEMENT. *TT
If: the automatic transmission in a new Q45 (F50) or G35 (V35) requires replacement, the Transmission Control Module (TCM) must be matched with the new transmission. This process is called "initialization". Use the instructions in the Service Procedure of this bulletin to perform the initialization process on an applied vehicle if the transmission is replaced.
Service Bulletin Num : 02010 Date of Bulletin: NOV 19, 2002
Summary: ENGINE WILL NOT START. VEHICLE IMMOBILIZER SYSTEM/NISSAN ANTI-THEFT SYSTEM (IVIS/NATS). *TT
This bulletin covers a new version of the Infiniti Vehicle Immobilizer System/Nissan Anti-Theft System (IVIS/NATS). This system, referred to as "NATS", is standard equipment on the 2003 G35 sedan and coupe. • NATS uses advanced anti-theft functionswhich are "password protected". This helps prevent "unauthorized access" into the NATS registration procedure. • Unlike earlier Systems, if the ECM is replaced with a new Nissan service part for the G35, NATS DOES NOT need to be Re-Initialized. NOTE: For the G35, the ECM and BCM do work together, but the BCM now controls the information necessary to "tell" the ECM to start the vehicle. IMPORTANT: The New NATS "C/U Initialization and Key Registration" Procedure in this bulletin is unique forthe G35. Do not use this procedure on any other NATS-equipped vehicles.
Service Bulletin Num : ITB01010 Date of Bulletin: ?
Component: POWER TRAIN:AUTOMATIC TRANSMISSION: SPECIAL FLUID REQUIREMENTS
Summary: Special Automatic Transmission Fluid Requirements
If: the automatic transmission in the new Q45 (F50) or G35 (V35) requires service, a new type of automatic transmission fluid MUST be used. The new fluid is Nissan Matic-J. See this bulletin for further details.
Service Bulletin Num : ITB00042 Date of Bulletin: ?
Component: POWER TRAIN:AUTOMATIC TRANSMISSION: OIL COOLER CLEANING
Summary: Automatic Transmission Oil Cooler Cleaning
Whenever an automatic transmission (A/T) is repaired, overhauled, or replaced, the A/T oil cooler mounted in the radiator must be inspected and cleaned. • Metal debris and friction material, if present, can become trapped in the A/T oil cooler and may build up as transmission fluid enters the Cooler Inlet. • This debris can contaminate the newly serviced transmission. • In severe cases this debris can block or restrict the flow of transmission fluid/oil. In either case, failure of the newlyserviced A/T may result. It will be necessary to back flush the cooler through the Cooler Outlet in order to flush out any built up debris.[/list]
Complete List of Recalls for G35 Coupe and Sedan -- Last Updated 6/6
NHTSA CAMPAIGN ID Number : 02V331000 Recall Date : DEC 12, 2002
Potential Number Of Units Affected : 36000
Summary: CERTAIN SEDANS FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, “LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT.” IN THE ASSEMBLY OF THE HEADLAMPS, IT IS NECESSARY TO HAVE A MEANS TO ADJUST THE HEADLAMPS. TAMPERPROOF CAPS TO PREVENT HORIZONTAL ADJUSTMENT OF THE HEADLAMPS ARE THEN INSTALLED. SOME OF THESE VEHICLES ARE MISSING THE TAMPERPROOF CAPS.
Consequence:
Remedy: DEALERS WILL INSTALL THE MISSING TAMPERPROOF CAPS ON THE HEADLAMP ASSEMBLIES. OWNER NOTIFICATION BEGAN JANUARY 20, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT INFINITI AT 1-800-662-6200.
Notes: CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
NHTSA CAMPAIGN ID Number : 02V245000 Recall Date : SEP 10, 2002
Component: FUEL SYSTEM, GASOLINEELIVERY:HOSES, LINES/PIPING, AND FITTINGS
Potential Number Of Units Affected : 18300
Summary: ON CERTAIN PASSENGER VEHICLES, THE FUEL HOSE CONNECTION FOR THE OUTLET OF THE FUEL PUMP WHICH IS LOCATED AT THE TOP OF THE FUEL TANK MAY NOT HAVE BEEN PROPERLY ATTACHED WHEN THE VEHICLE WAS ASSEMBLED AND COULD COME LOOSE WHILE DRIVING OR WHEN STARTING THE ENGINE.
Consequence: IF THE CONNECTION COMES LOOSE WHILE DRIVING, THE ENGINE WILL STOP RUNNING DUE TO LACK OF FUEL, INCREASING THE RISK OF A CRASH. ALSO, IF THE CONNECTION COMES LOOSE WHILE DRIVING OR ATTEMPTING TO START OR RESTART THE ENGINE, SOME FUEL WILL DISCHARGE FROM THE FUEL PUMP. IF THIS SHOULD OCCUR IN THE PRESENCE OF AN EXTERNAL IGNITION SOURCE, A FIRE COULD RESULT.
Remedy: DEALERS WILL INSPECT AND, IF NECESSARY, PROPERLY ATTACH THE FUEL HOSE TO THE FUEL PUMP. OWNER NOTIFICATION IS EXPECTED TO BEGIN OCTOBER 7, 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT INFINITI AT 1-800-662-6200.
Notes: ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
NHTSA CAMPAIGN ID Number : 03V200000 Recall Date : MAY 28, 2003
Component: SERVICE BRAKES, HYDRAULIC:SWITCHES:BRAKE LIGHT
Potential Number Of Units Affected : 60000
Summary: ON CERTAIN SEDAN AND COUPE MODEL VEHICLES, THE BRAKE STOP LAMP SWITCH MAY MALFUNCTION.
Consequence: IF THIS OCCURS, THE BRAKE LAMPS WILL NOT ILLUMINATE WHEN THE BRAKE IS APPLIED, WHICH COULD RESULT IN A CRASH WITHOUT WARNING.
Remedy: DEALERS WILL REPLACE THE BRAKE LAMP SWITCH. OWNER NOTIFICATION IS EXPECTED TO BEGIN ON JUNE 30, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT INFINITI AT 1-800-662-6200.
BillR
Old Jun 7, 2003 | 09:44 AM
Gordgee's Avatar
Administrator
Re: Complete list of TSB's
BillR:
Thanks for the great info. I moved htis to our new TSB forum.
<font color=green>GG</font color=green>
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
Detailed Image
Sep 18, 2015 03:43 PM
Detailed Image
Sep 17, 2015 07:38 AM
Detailed Image
Sep 11, 2015 08:37 AM
