Technosquare Reflash + Vortech?
Old Jun 10, 2006 | 09:01 PM
Dan_K's Avatar
Anyone have this combo? I was thinking of doing to L-Spec reflash before getting the Vortech installed. Opinions?
Old Jun 10, 2006 | 09:33 PM
urban's Avatar
I have the L flash but I had it done just after the Vortech install due to I kept hitting the rev limiter and now it is raised to 7100rpm or is it 7600rpm.. oh well one of them.
Old Jun 10, 2006 | 09:34 PM
Kamal34's Avatar
no I would suggest getting reflashed after the vortech and before the major tuning... anyone else have suggestions?
Old Jun 10, 2006 | 10:06 PM
urban's Avatar
Well it actually depends on what you are doing in regards to mods as I did the flash just for one reason only and that was the rev limiter, the rest of the tuning for all the mods I added afterwards I used the Unichip.
Old Jun 10, 2006 | 10:43 PM
Dan_K's Avatar
Well I am going to go with the stock SS box that comes with the Vortech Kit. Would it actually matter if I did it before or after the install, since the L-Spec is just raising the limiter and not messing with any of the fuel maps or other Ecu functions?
Urban - What do you think? Also, did raising the limiter give you more top end power or does the power drop off after 6.5k anyway?
Old Jun 11, 2006 | 12:01 AM
urban's Avatar
Well I would get it tuned with the ss box after the vortech and a few other mods are installed but if you are not going to do any other add ons for awhile then get it tuned and raise the rev line because I can tell you now that if you just install the vortech and do not get the flash you will hit the limiter every time.
I will post my dyno sheet tonight which I just got this Friday and you will see that the higher rev line helps a whole lot. I actually tuned mine a little fatter and got 430rwhp but I did managed 440rwhp.
Old Jun 11, 2006 | 12:16 AM
urban's Avatar
Here is my dyno sheet, just look at the red line and see how it is still climbing even at 7500rpm....sorry for the blurry picture but i just cannot get it to focus real well.
Old Jun 11, 2006 | 12:27 AM
Dan_K's Avatar
Ok, so get the reflash before the actual tune, right? How much did the L-Spec reflash cost you?
Old Jun 11, 2006 | 12:36 AM
urban's Avatar
Does not matter in which order you do it but the L flash is a must when you go FI I cannot remember how much I paid but I think it was around 349 when I did it.
Old Jun 11, 2006 | 01:01 PM
Mr_pharmD's Avatar
I would get the F-spec bc u will need them to raise your idle. I'm not sure if the TS allows u to change 2 of the 3 maps like AAM does so your car doesnt try to advance timing up top to save fuel.
Hey urban, nice dyno. did u get it tuned at scotts performance? His dyno is the only one i know that the rpms are way off.
Old Jun 11, 2006 | 03:21 PM
urban's Avatar
Actually I have 2 dynos so that I get a better picture of what I am doing, this one is at Scott Performance and I have another from Z car garage, both very similar hp numbers but what I was trying to point out is that the hp is still climbing so I have more to play with I just need to figure out my next plan of action
Old Jun 11, 2006 | 03:45 PM
Dan_K's Avatar
Well, I could go to the dealer to raise my idle since I have an early '04. Shouldn't you get the reflash before because when they are tuning the fuel maps/timing, they have to account for a higher redline? Or am I completely wrong?
Old Jun 11, 2006 | 05:55 PM
Mr_pharmD's Avatar
u can send the ecu in when u get it installed so there's no down time. The L-flash wont let u change the maps so your ecu will keep trying to advance time up top and lose potential hp.
Old Jun 11, 2006 | 07:00 PM
Dan_K's Avatar
Well, shouldn't tuning with the SS box solve this problem? Isn't that what tuning is for?
Old Jun 11, 2006 | 08:17 PM
urban's Avatar
Correct... I hate to mess with flashing of the ecu just tune it, I would use the ss box or whatever other piggyback system you have to tune the car.
