Is temperature a huge factor on the Dyno?
Old Aug 14, 2006 | 10:10 PM
G35_TX's Avatar
DAVEB = CLUELESS G35 OWNER
LOL!!! Another stupid post
So your saying the Dyno knows when the ECU is pulling timing and cutting power because of engine coolant? Really? Wow, got any data backing that up?
Btw, this proves you do not have a clue about how dynos work or obviously the G35 period.
Originally Posted by DaveB
That is kind of the point for the SAE correction. Naturally when temps are hotter, the ECU will pull timing and add fuel to keep the motor from detonating. Every car using an electronic control will do this. Same goes for baro pressure. The pressure sensor relays the baro information to ECU because when pressure is high, more 02 is freely pumped into the motor therefore fuel must be added or else the motor will experience detonation. The SAE correction is the generally accepted correction factor that compensates for what the ECU will do under ambient conditions. However, it is just an estimate. If the motor is scalding hot, it may impact power somewhat, though on the track, my G35 and my friend's G35 doesn't seem to care if the motor is hot or cold because trap speed remains constant.
Concerning this particular dyno, the SAE CFs are wildly different 0.94 vs 0.99 (close to ideal). It appears that the first dyno was done on a day what had extremely good air (high baro pressure) and that the second dyno was under more typical ambient conditions. Though a 0.94 vs 0.99 doesn't seem like a lot, it really is when it comes to dynos. The data tends to get skewed the further the SAE CF gets away from 1.00 (higher or lower). This dyno shows that his car actually made less power with the Crawford High Flow Cats, Crank Pulley, and Unichip. IMO, I think the car is probably making close to the same power it did during the first dyno, but the SAE CF of 0.94 skewed the data a bit. Also, from the dynos I've seen for UDPs, high flow cats, and the Unichip, none of these mods make any measureable power. Unichip isn't a piggy back adjustable ECU. Correct?
Also, wasn't it you that actually saw a small loss with the Crawford high flow cats?
Old Aug 14, 2006 | 10:14 PM
G35_TX's Avatar
Well let's see. My car was dynoed once 4 times in a row, maybe it was 5. I forget. But it lost almost 15 hp because of back to back pulls. If a DYNO corrected for that then my car wouldn't have lost 15 hp. It lost it because the car was heat soaked, coolant temps were way to high, the car removed timing.
Old Aug 14, 2006 | 10:34 PM
DaveB's Avatar
......Well let's see. My car was dynoed once 4 times in a row, maybe it was 5. I forget. But it lost almost 15 hp because of back to back pulls. If a DYNO corrected for that then my car wouldn't have lost 15 hp. It lost it because the car was heat soaked, coolant temps were way to high, the car removed timing.
Well let's see, my car did a 14.35@97.5mph, a 14.39@98.1mph, and a 14.32@97.8 all on back to back passes within minutes of each other. No cool downs. I think we can be certain that the engine would be pretty dang hot. Then I let the car cool for an hour and the car ran 14.41@98.0mph. 45 minutes later, it did another high 14.3. All 60 foots were within .05 seconds of each other. If anything, my car was quicker with a hotter engine.
Interestingly and something you apparantly haven't seen, but nearly every G and Z dyno I've seen shows the VQ gaining power after each successive pass. That kind of data goes against what you're preaching because we can be pretty certain that each dyno was done within 5-10 minutes of each other.
Most gearheads know that an engine makes the best power when the heads and block are hot and the intake charge is cold.
Who's right? Who's wrong? We'll never know.
erikill's Avatar
SAE Standards
Document Number: J1349
Date Published: August 2004
Title: Engine Power Test Code-Spark Ignition and Compression Ignition-Net Power Rating
Issuing Committee:
Scope:
This SAE Standard has been adopted by SAE to specify:
* a. A basis for net engine power rating
* b. Reference inlet air and fuel supply test conditions
* c. A method for correcting observed power to reference conditions
* d. A method for determining net full load engine power with a dynamometer.
I figured I'd take the opportunity to check on SAE's website. I don't see any ECU corrections here?
Old Aug 14, 2006 | 10:36 PM
G35_TX's Avatar
1) We are talking about a Dyno here not a track. There are more variables on a freakin track than a Dyno. And the car is getting HEAT-SOAKED by not moving anywhere on a dyno.
Hmm, strange, all the dynos I have seen show then loosing power the more passes they do. Where is your dyno? Where is your experience of over 100+ dyno runs? Didnt think so, you don't have any.
It's obvious you aren't right here. You proved that above.
Old Aug 14, 2006 | 10:38 PM
G35_TX's Avatar
Exactly Eri. SAE does not correct for Engine temps/knock retard/coolant temp/oil temps or even oil temps in the tranny/rear diff or even tire pressure temps/psi.
Old Aug 14, 2006 | 11:08 PM
DaveB's Avatar
So a car running on dyno with the hood up, a 50mph fan blowing on the motor/raditator, and spinning a 2,000lb roller will run hotter than a car running with the hood down, never shut off between 3 passes, accelerating a 3,500lbs w/driver, and having to deal with aero dynamic drag? Is it me or is the dumbest argument I've ever heard
Hmmm, I don't know what dynos you're looking at. Unlike you, I actually POST the data to support my arguments. I don't ask people to do the search themselves. I do the work so that others will see the data. All these threads were found within 5 minutes of searching just this site and every thread I read that had consecutive dynos showed EXACTLY what I'm talking about. Consider yourself owned, Holme Slice.
https://g35driver.com/forums/showthr...highlight=dyno
And the nail in the coffin:
"As you noticed, i had 3 runs, and each run consecutively pulled higher numbers, meaning, the ECU was learning after each pull. . .and perhaps i woulda pulled higher numbers if i did more runs......"
Old Aug 14, 2006 | 11:19 PM
trey.hutcheson's Avatar
Hard to argue, but I've never been fortunate enough to attend a garage that had a fan capable of even 50mph. Most garages have itty bitty fans. Hell, I've seen posts on here and my350z(mostly newer guys) that claim a fan wasn't even used during a dyno.
Regardless, we're getting a bit off topic here.
Old Aug 14, 2006 | 11:28 PM
G35_TX's Avatar
No sir, you proved NOTHING. Except a few cars had more cool down time.
1) If the car is not at opperating temperature, sure hp will increase run to run. If car is at operating temp on first run then it will go the other way around down. This is why controlling the cars coolant, oil, temps is very important.
I have many years and dyno runs behind my belt. You barely have a hand full and none on your G35.
And for the matter I always back my statements up. You NEVER DO. Except post other peoples data that posted on here. I posted this info straight from the dyno machine I was at.
Here is 6, yes 6 dyno runs I fixed up to put online to prove my point. And there are MANY more on this site.
Yes HEATSOAK causes a problem with dynos.
And the only person OWNED Home Slice was yourself. Good job.
Old Aug 15, 2006 | 12:18 AM
DaveB's Avatar
The two local shops I've been to have high end fans. These aren't you're typical home-type fans. These are belt driven fans with 5hp motors. They'll dang near take your shirt off if you're standing in front of it. The blower area is focused on a 2'X2' area about 2 to 5 feet in front of the fan so the radiator gets a majority of air. A secordary, more standard style, fan blows across the intake manifold. These shops consistently see higher end rear engien exotics and 600-800whp+ Vipers/Supras/turbo Cobras, etc and the last thing they want is the car to overheat on the dyno. Using a standard fan won't cut it.
Here is the shop I've always gone to. http://www.gomcracing.com/gallery/ picture 45 with the twin turbo Cobra shows the fan.
I too read about people dynoing without a fan. My question is why? Doesn't the shop understand the importance?
Old Aug 15, 2006 | 12:21 AM
Earl's Avatar
Hey guys,
There's nothing to be gained by debating the "Clueless".
seagrasser
May 3, 2022 09:43 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
mattdg35
Sep 14, 2015 11:28 AM
