EXPERT OPINIONS: Do I need a tune with thes mods?
Old Jan 24, 2007 | 02:33 PM
Jtrain's Avatar
your probably running pretty rich on the top end, get a dyno and find out. From what I got from my mods, I got all over again when I tuned. Its a great mod, you wont be disappointed
Old Jan 24, 2007 | 02:43 PM
Jeff92se's Avatar
Red Card Crew
Diamond, look at the bold part. Although you "probably" won't need a tune, all cars are different. And the only way to tell is if you get it dyno'd to see what your PARTICULAR car's a/f are. But since your bro is a tech, he might be able to run your car on a handheld consult and look for you. ie.. test run.
BTW. Since he's a tech, have him advance your timing a few degrees.
Old Jan 24, 2007 | 02:46 PM
Jeff92se's Avatar
Red Card Crew
Actually that's incorrect. The ecu is plenty powerful. But the reasons for a tune aren't due to the ecu's power. It's the programming
At anything less than WOT, the ecu should be able to use it's closed loop program to adjust a/f ratios to it's target value. ie.. 14:1, 13:1 or whatever.
BUT at WOT, where the ecu is using it's open loop program is when it needs help.
I could be mistaken. But I haven't read of too many guys needing a/f tunes at part throttle. At least not with any na mods.
Originally Posted by b00stedjustin
that pretty much sums it up. Our ECU isn't powerful enough to figure out the best air/fuel ratio's if we are changing parts, which changes how much air, and depending on you mods, how much fuel you are enjecting is the best for driving.
Old Jan 24, 2007 | 04:10 PM
wnt1bd's Avatar
Originally Posted by delion21
I dont think that you necessarily need a tune with the mods you have.l The ECU learns and adapts to the minor mods that you install. I have Injen CAI, DC Headers and Injen Exhaust and my car out performs stock G35s.
However tuning will maximize those mods for sure.
I personally don't think the ECU "learns" that much.....you see what I have in my sig, and I am running lean. I want to get headers, but running lean is dangerous, and the more "breather mods" you install the leaner your car will run. As far as tuning, there is a broad range of what you can do, Apexi Safc, Utec, reflashes all will achieve what you need. depending on what your budget is will determine what you will get.
My last Dyno I had a 14.5-14.8 lean condition, prime would be 13ish.
Old Jan 24, 2007 | 06:57 PM
Diamond G35's Avatar
Wow....
This actually is turning into a pretty informative thread. I'm impressed.
I have contacted MRC to see if they can reflash. I really don't want or need something like a UTEC with 5 different positions fully adjustable, etc.
But I do want to optimize and I do want to run safe.
Old Jan 24, 2007 | 07:30 PM
Beebo's Avatar
Thumbs up
Originally Posted by Diamond G35
Guys,
My combo is simple, something the ECU can work around, Stillen cat-back, drop in K&N, Z-Tube, 5/16" spacer, and that's it.
im doing the same
Old Jan 25, 2007 | 08:18 AM
Good choice.
Old Jan 25, 2007 | 11:35 AM
wnt1bd's Avatar
OK, lets focus on the question at hand......are you safe? Maybe........if it's real cold and the gas you use somehow didn't reach it's 91-93 octane, and you happen to race so fool on a emty roadway.......you MAY be in trouble. The reason you don't read much about people getting retunes for "simple" breather mods is not many people think they should! alot of guys on here go by what the G gods say.......Every car is slightly different......I have stopped modding until I get a retune. It's the safest thing to do.......you problably be safe, but the extra measures wouldn't hurt. Nobody really knows what unsafe is on every engine. Now my question for you is, Why is UTEC overkill? I would think it would be the best choice......you have upgradabilty(sp). A reflash would be good till the next mod, then guess what reflash. If you look around you can get real good deals on UTEC. Just my opinion......get what makes you happy.
Good Luck
Old Jan 25, 2007 | 11:47 AM
Jeff92se's Avatar
Red Card Crew
Good Luck
Also if you tune it yourself, you have to have the knowledge to do so safely.
Old Jan 25, 2007 | 12:34 PM
Jtrain's Avatar
BTW: Considering he just said what I said, but just wanted to make a point of being an ***, he's a "probably" a perfect match for that guy you know who "probably" likes guys, you've just never really asked
Typos FTL?
Old Jan 25, 2007 | 01:57 PM
JC79G35's Avatar
Good Luck
Thanks for that info. That is my main concern is my engine's longevity. I have no intentions on modding my car further (that is unless I win the lotto :P ), so a reflash will do the job.
Old Jan 25, 2007 | 02:24 PM
I have been advise against a re-flash. It's sort of like putting a large patch over a small cut and hoping you can absorbe the blood.
I'd rather something more personally tuned to my car.
Old Jan 25, 2007 | 03:41 PM
redred7139's Avatar
Ok, sorry for being ignorant, but can someone explain to me what the different tuning methods are (chip/reflash/timing) and what they do? I've been wondering this myself for a while now and I have the same mods sans the exhaust.
Old Jan 25, 2007 | 04:34 PM
wnt1bd's Avatar
Ok, this most of this tuning stuff has to do with how much air & fuel you are burning with each stroke of your pistons......now before I go farther let me just say I am trying to explain this in it's simplest forms.....so when you guys start saying there is more to this, yes there is, this is a crash course............
When your car is not burning enough fuel it is called a lean condition and is bad.....on the reverse side having to much fuel and not enough air is rich......a rich condition is "back firing" that's when unburned fuel is burning in the exhaust....still bad , but lean is worse. Timing is has to do with the duration that your valves are open to allow air/fuel into the cylinder. That's the basics....there is ALOT more that I am nowhere qualified in detailing. tuneing just alows you to control the iming, fuel and air that your vehicle is using and when.
Old Jan 25, 2007 | 04:38 PM
  #30
Jeff92se's Avatar
Red Card Crew
That's incorrect. There is TWO timing terms. Ignition timing and cam timing.
That is correct.
Again if you are referring to ign timing above also, you would be incorrect. Ign timing is when the spark plug is told to fire in relation to the piston position.
