Feeling less Horse power/ Torque after few mods?
Old May 7, 2007 | 05:24 PM
  #32
Skaterbasist's Avatar
Retired SuperMod
Originally Posted by Damon
the flash will not do much for you if you are NA. I only got 7rwhp on it. I dyonoed before and after. Every little bit helps, but if I had the chance to do it again, I wouldn't
A flash isnt only for power. You have the wrong idea of a ecu reflash if only wanted to see hp gains.
An ecu reflash will correct any wrong mixtures; If you're running too lean, its bad for the engine. If you're running to rich, its also bad. And this will always be an issue with alot of bolt on mods (breather mods).
An ecu reflash will give you the perfect AFR, which should make your car feel more alive. It usually does give you anywhere around 10 hp & tq in the top and improve your powerband, but thats not everything that should matter with the flash.
Old May 7, 2007 | 10:58 PM
  #33
OCG35's Avatar
skaterbasist is absolutely correct. The comment that a flash if NA does nothing could not be farther from accurate.
It is futile if you have no breather mods. It is completely pointless to reflash a stock car unless for whatever reason you want the rev limiter bumped up and the speed limited deleted.
On the other hand - if you have substantially increased the air intake and exhaust it is imperative to adjust the A/F... otherwise you will fall prey to the unknowing that think their new mods suck.
The Technosquare ECU also addresses drive by wire software that gives better throttle response. It is a real and viable alteration - I definitely felt it the original time and the updated version.
If you dispute this info you are ill-advised and/or simply do not have first hand experience and should research more.
Old May 8, 2007 | 01:03 PM
  #34
ballisticus's Avatar
^^+1
The TS reflash is definitely worth it if you have the right exhaust. You don't. 3" piping with N/A is totally wrong, but it has nothing to do with needing exhaust "back pressure". It has to do with low RPM exhaust VELOCITY.
My advice? Keep the test pipes, dump the 3" exhaust and go Fast Int or Stillen, wait a week, re-dyno with the A/F ratios, send the results to TS for reflash. You will be happy.
Old May 9, 2007 | 04:05 AM
  #35
G-Ride Canada's Avatar
Originally Posted by ballisticus
^^+1
sounds good my man, what do you think of HKS hi-power? would that be a good exhaust too?
thanks
Old May 9, 2007 | 04:43 AM
  #36
Retired SuperMod
thanks
Just get a 2.5 (or 2.25).
If you ask which exhaust is "better", you're going to get a ton of preferences and opinions.
In my mind, I like these 3 in order:
1) Stillen
2) Fast Intentions
3) HKS
Just see which one suits you best, and go on from there.
Goodluck man!
Old May 9, 2007 | 05:46 AM
  #37
imtheprez's Avatar
if u think ur feeling less power esp. in low end go by some underdrive pullies..that should help
Old May 10, 2007 | 12:46 AM
  #38
1) Stillen
2) Fast Intentions
3) HKS
Goodluck man!
yes FI and HKS are my top ones judging from the sound clips...ya i know it's different in person. but hey thanks man! you been patient with me for the past week!
Old May 10, 2007 | 12:48 AM
  #39
yes i thought about that, but the installation would probably cost the same as the parts....
good suggestions tho
thanks!
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
yosip1115
Aug 26, 2015 10:46 AM
Mattdi
Aug 23, 2015 11:27 PM
Raven7
Aug 14, 2015 04:40 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
