Feeling less Horse power/ Torque after few mods?
Have any of you feeling less torque or hp producing out of your car after some mods? I have 15/6 MD iso Spacer, strup headers and test pipes, stock Y pipe and Top Speed Pro 1 exhaust. or I might have a leak somewhere again...???
will a worn out clutch effect the situation that I'm experiencing?
please help! any suggestions would be helpful!!!
Originally Posted by Jtrain
I seriously doubt reseting will do much.
Managed for sure will help, but it aint cheap.
thanks!
GO ECU Reflash/Piggy back for the best results.
Originally Posted by dofu
You're probably just getting used to the gains... sounds like it's time for more mods!
Originally Posted by skaterbasist
It might help temporarily, until the ECU adjusted.
GO ECU Reflash/Piggy bank for the best results.
Originally Posted by G-Ride Canada
yes, i think that's an option too, so it would be better than getting engine management system? I can't remember the places that I can send to, but that's the idea right? take off my ECU and send to be reflashed?
Are you staying NA, or are you going FI?
If you're staying NA, then an ECU reflash @ Technosquare should be more than enough; trust me, you'll like it.
If you're going FI, then UTEC might be worth it.
What are your future plans?
thanks for your advice
