Too lean? Too rich? confused??
Old Aug 30, 2007 | 04:15 PM
r0csfinest's Avatar
Question Too lean? Too rich? confused??
All right when I have Stillen CAI, FI exhaust and got TurboXS test pipes installed yesterday. When I got WOT now there is smoke coming from the exhaust. I'm sure thats normal from the test pipes but some coming from the engine as well?
Old Aug 30, 2007 | 05:08 PM
CB_Skyline_03's Avatar
when you say engine, where exactly do you mean?
Old Aug 30, 2007 | 05:09 PM
617G's Avatar
CFW (Carbon Fiber Whore)
what color is the smoke?
Old Aug 30, 2007 | 07:34 PM
r0csfinest's Avatar
i see it coming out from under the hood. the smoke is kinda a light color
Old Aug 30, 2007 | 08:31 PM
Drewer's Avatar
Exhaust leak? Does it smell like exhuast? Can you see where it's coming from?
Old Aug 30, 2007 | 08:35 PM
ISMSOLUTIONS's Avatar
OK - smoke from exhaust pipes is normal, not because of test pipes, but from the grease used to lubricate the mandrel of the bender. There is a possibility that there is grease on the outside of the pipes as well, and it's just burning off. Is the system and testpipes SS, polished SS or aluminized paint?
To be safe - check your oil level and other fluids, and if the car is driving fine, give it a day or two.
Rick
Old Aug 30, 2007 | 10:41 PM
ttrank's Avatar
Grocery getter
If they are new pipes and/or have a little fluid on them it will burn off. See if it goes away in a day or so.
Old Sep 1, 2007 | 06:04 AM
OCG35's Avatar
he mentions coming from the engine as well...
white smoke?...
Old Sep 1, 2007 | 12:59 PM
white smoke?...
Yea - oil burn off from the testpipes, maybe wd-40 to loosed the stock bolts got on the header, etc.
Rose M
Oct 12, 2015 10:00 AM
Rhinos7777
Sep 6, 2015 05:36 PM
