Installing wideband 02 sensor
Old Sep 11, 2007 | 02:04 AM
805g's Avatar
Can somebody please point me in the right direction as to how to install my bosch wideband 02 sensor.
IF ANYONE IS IN SOCAL THAT CAN HELP WITH A UTEC INSTALL/SETUP, PLEASE CONTACT ME, I WOULD GREATLY APPRECIATE SOME DIRECTION.
Thanks all
Old Sep 11, 2007 | 11:53 AM
805g's Avatar
bump
Old Sep 11, 2007 | 01:22 PM
gqong's Avatar
one side is power = just do positive ignition and ground ( + and -)
the other side just connects to the harness for the o2 sensor which needs to be screwed into the bung drilled onto your cats/testpipes whatever.
thats it.
Old Sep 11, 2007 | 11:41 PM
805g's Avatar
so i need to get something drilled into my stock cats?
Thanks gqong
Old Sep 11, 2007 | 11:54 PM
gqong's Avatar
thats correct youll need a bung that fits the o2 sensor.. if you have the aem gauge it should have came with it. you need to drill a hole and weld the bung and screw the o2 sensor into that.
Old Sep 12, 2007 | 01:06 AM
805g's Avatar
how much do exhaust shops charge for this? i need a lot more direction in what needs to happen before i bring it in to one.
Old Sep 12, 2007 | 09:51 AM
FI'ed G's Avatar
it's not a straight plug in (at least for Innovate), at least for Innovate I know it needs to be air calibrated before you plug it in else the reading will be out of wack.
Old Sep 12, 2007 | 11:33 AM
Matt at PF's Avatar
yes it does. Find a good muffler shop to weld the bing in. It should cost that much.
Old Sep 12, 2007 | 12:17 PM
FI'ed G's Avatar
/\ I'm just basing my experience with Innovate were my buddy had to go through 5hrs worth of install after Innovate finally stepped in and said that the sensor needed to be air calibrated.
Old Sep 12, 2007 | 12:22 PM
805g's Avatar
I Have A Bosch Sensor........
Old Nov 12, 2007 | 07:29 PM
805g's Avatar
help?
Old Nov 12, 2007 | 09:05 PM
zazaracing's Avatar
Team Transport Member
have the bunt welded as close to your engine as possible before your stock o2's if you can.... then depending on which gauge you using it needs to be calibrated.... I wouldnt pay more than $30 to have it welded
Old Jan 5, 2008 | 04:37 AM
Mad A's Avatar
Calibrating an Innovate wideband is very easy to do. Should be in the instructions that came with it. Haven't done it in a while but as far as I remember you have to let the car sit for a several hours so it's cool, turn your key to Accessory (don't start the car), then hit the button on the gauge three times, display should start blinking, hit it one more time before it stops blinking, and it will calibrate. Don't do this after driving the car as your readings will be off, let it sit for several hours and cool down completely.
If you have an AEM, I believe they are ready to go right away (someone correct me if I'm wrong). My AEM is in the mail on it's way, so I'll find out for sure soon enough.
Guy's with widebands, did you use a dual channel (one sensor for each bank) or did you just use one and place it on the y-pipe where both sides meet? I've heard that although it's advisable to do both sides and as close as possible to teh engine, the readings will be pretty much the same at the y-pipe.
Old Jan 16, 2008 | 01:31 PM
sliderg35's Avatar
To calibrate the Innovate, you have to unscrew it and let it dangle in the air before you press the button. At that point, event if it was faily hot before, it won't be after hanging a bit.
Old Jan 16, 2008 | 01:33 PM
06g35meister's Avatar
$20 (for me) get the bung welded, screw in the sensor, connect the terminals and voila!!! OH and make sure you get it welded into the top of the TP or wherever! If you put it in the bottom youre readings will be off and eventually youll have to replace the sensor (not cheap):
SENSOR
__| |_______________________________
PiPING
___________________________________
if you can see what i tried to show, youll get it.
