rev up on norev engine harness? ECU!!
Old Nov 22, 2008 | 12:54 AM
G3.5-Unit's Avatar
ok im running a rev up motor 06 on a 03 engine harness theses some cam sensors obiously not hooked up i was woundering if just be getting my ecu reflashed will some how shut down thoes sensors? and make the engine run proper?
Old Nov 22, 2008 | 05:17 PM
str8dum1's Avatar
u have to have a matching harness and ecu from a non-revup motor.
Old Nov 22, 2008 | 06:27 PM
G3.5-Unit's Avatar
wait let me get this right . i have a non rev ecu and i have a non rev engine harness. i have a rev up motor though , so i can just reflash the ecu and it will shut thoes sensors down so my engine can run proper? will this allow me to rev to the 7200 rpm the rev up model allows?
Old Nov 23, 2008 | 01:57 PM
badtziscool's Avatar
The rev-up motor has variable valve timing on BOTH the intake and exhaust valves. The non-rev-up motor only has variable valve timing on the intake valves. Hence the missing cam sensor plugs.
Hasanbaloch
Feb 29, 2024 08:45 PM
03sedang35
Aug 29, 2015 07:56 PM
derres
Aug 28, 2015 03:27 PM
fredthesnail
Aug 27, 2015 09:26 AM
Gookiecrunch
Aug 19, 2015 12:00 PM
