Motordyne 5/16 vs Blox 5/8 Spacer before,after dyno runs
Old Oct 17, 2012 | 01:21 AM
Tolboothwilley™'s Avatar
1/2" spacer... www.motordyneengineering.com is one version of it (common)
Old Oct 17, 2012 | 01:57 AM
dj714's Avatar
So is the 1/2 better then the 5/16?
Old Oct 21, 2012 | 09:53 PM
Orbital1's Avatar
Supposedly the 1/2 is better for high RPM's while the 5/16 is better for mid range. Which one is better, well that's for you to decide. Pretty much ask yourself how you drive and pick the proper spacer. 90%+ of the time I'm daily driving so the 5/16 (mid range) works best for me.
Old Oct 21, 2012 | 10:47 PM
dj714's Avatar
[IMG][/IMG]
Look what I found yesterday, looks like I already have a spacer ^^
Old Oct 21, 2012 | 10:51 PM
thescreensavers's Avatar
Mr.202?
^ yes you do, looks like a 5/16th
Old Oct 21, 2012 | 10:58 PM
dj714's Avatar
Yes I was so stoked to find that. Now I just need to replace the camshaft sensor get some test pipes and possible a pop charge filter.
Old Nov 4, 2012 | 01:34 AM
PlastiDippinG's Avatar
I don't understand how there can be such a difference just by the manufacturer? Any feedback here? I understand the materials are different, but is the blox is also thermal,and NASA quality for heat, then why the difference? If it let in more heat,higher temps could make a difference,but i don't see that being possible here?
also,why do some kits come with the manifold gasket when you buy the plenum spacer,and some don't? is that a must to change when doing this upgrade?
Anyone feel free to chime in on this.
Old Nov 11, 2012 | 01:58 AM
I used to have the BLOX - its made from ABS (thermal plastic) which prevents heat from transferring up.
My upper plenum was always cooler than when I had my Motordyne 1/2"
The difference of the plenum spacers is size mostly - the smaller size actually flows air better
The gaskets are all about heat exchange - they help but not much and not worth the price IMO - since i have them
Old Jul 21, 2013 | 03:28 AM
Al Janinny's Avatar
How are these very different results possible?
Old Jul 23, 2013 | 07:17 AM
Al Janinny's Avatar
Xxx
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
IkonG35
Aug 10, 2015 09:33 AM
deathsupport
Canada
Aug 2, 2015 10:13 AM
sick_sixspeed
Jul 21, 2015 01:59 PM
sick_sixspeed
Jul 20, 2015 10:25 PM
