Utec hot engine starting issues
Old Jun 22, 2009 | 11:29 PM
Need4SPEED05's Avatar
I've heard people with Utec have been having problems getting their car to start when the engine is still hot. Is there a fix to this? What was the problem? The reason I ask is because I'm planning on going fi with UTEC tuning. UTEC owners please chime in.
Old Jun 22, 2009 | 11:38 PM
Chef-j's Avatar
Used to have problem, but not anymore. So it can be fix.
Old Jun 23, 2009 | 11:12 AM
mind sharing how you fixed the problem? Can you program the utec unit to not interfere with the factory ecu at start up? Or can the utec only be programmed at rpm intervals? Thanks for the help.
Old Jun 23, 2009 | 11:34 AM
str8dum1's Avatar
that's teh problem, the UTEC do not interfere with the stock ecu at startup. The stock ecu is programmed form 380cc injectors and dumps fuel for that size. It doesnt know you have bigger injectors but still tries to dump fuel for the same amount of time, hence flooding the motor (ie hard starts)
some cars are more finicky. Only solution is a stock ECU reflash to tell the car to reduce its injector times.
Old Jun 23, 2009 | 01:53 PM
Thanks for the info. I see why this problem occurs with those people who install larger injectors. How many hp are the stock injectors good for? I see people upgrading to some pretty high flow injectors (600cc) but aren't pushing more than 400whp. Is this necessary. I'm looking at the Turbonetics kit and I believe it has 440cc injectors. Is the output difference small enough to not require a reflash. I may have read that this is the highest injector upgrade you can go for it to not have the starting issue...
Old Jun 24, 2009 | 01:33 PM
Chef-j's Avatar
If you are looking for big power its good to go with bigger injectors. You might can walk away from hot/cold start
with 440 inj but I don't have a experience with 440 inj, so don't trust me on that.
I'm running 600 inj with utec/reflash ecu. Strdum1 did explain enough about utec.
Old Aug 1, 2009 | 11:50 AM
t6378tp's Avatar
stock injectors are only good for about 320whp maybe you can push 350 with raising the fuel psi but I would not suggest it
like stated ^ 444 inj will be fine
Terry_G35
May 9, 2020 01:39 AM
D1dphresh
Aug 7, 2015 06:10 PM
EliteG
Engine - Electrical
Aug 5, 2015 07:50 PM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
