Dyno Tune Gains
Old Mar 15, 2010 | 10:20 AM
rleroy4298's Avatar
Dyno Tune Gains
I went up to get my car dynoed and tuned on Saturday and was a little dissappointed in the outcome of my numbers. It was done in Houston on a Dyno Dynamics machine. My mods are listed below. Oh, and I didn't turn my VDC off during the tune and maybe thats why the numbers seem a little lower, but I didn't that that would matter that much. Let me know what you guys think.
Ryan
2005 G35 6MT Sedan
Motordyne 5/16" Spacer
Motordyne MREV2 Manifold
Z Tube w/ filter
Stillen Gen 2 Exhaust
Attached Thumbnails Dyno Tune Gains-hp-torque-gains.jpg   Dyno Tune Gains-hp-torque.jpg   Dyno Tune Gains-hp-afr.jpg
Old Mar 15, 2010 | 10:40 AM
Swivel's Avatar
Moderator
So gains were about 10hp/10tq? Hard to tell exactly from the graph only.
Old Mar 15, 2010 | 10:43 AM
rleroy4298's Avatar
Ya it was a gain of 11 HP and 10TQ
Old Mar 15, 2010 | 11:06 AM
migueralliart's Avatar
Vortech that b1tch!!
Old Mar 15, 2010 | 11:07 AM
rleroy4298's Avatar
Ya I wish...dont have $5k to blow.
Old Mar 15, 2010 | 11:09 AM
That's why I chose to spend money first in brakes/suspension/tires and save for the big BANG!
Old Mar 15, 2010 | 11:15 AM
Swivel's Avatar
Moderator
Anyone with a helpful comment for the OP? What numbers should he have reasonably expected? I've seen claims of 20-30 with a tune and not-too-dissimilar mods.
Old Mar 15, 2010 | 11:20 AM
Seriously now,
I run the cobbaccess and I have seen a max increase of 25 whp, but again I have ported cyl heads and some other goodies. You should check if the car is running properly or if there is something wrong with it, with those mods you should be seeing close to 250whp.
Old Mar 15, 2010 | 11:27 AM
rleroy4298's Avatar
So does it matter that the VDC was left on? How do I check to see if the car is running properly internally? It feels fine to me.
Old Mar 15, 2010 | 11:37 AM
I think theres a list of things to check prior to dyno a car I don't know maybe people can chime in I would check the following:
Check the compression on the cylinders
Check the spark plugs
Oil level
COolant level
O2 sensors
Catalytics
Intake filter
Check OB2 diagnostics and see if there were any codes recently
Fuel filter
If it were me I would probably do all of these BEFORE going to the dyno. otherwise it will be money wasted if there was a problem with the car.
Old Mar 15, 2010 | 11:48 AM
rleroy4298's Avatar
I guess I should have brought it to my mechanic to run some tests on it prior to the dyno?
Old Mar 15, 2010 | 11:59 AM
rleroy4298's Avatar
Maybe the dyno was under rated as I ran a low 14 1/4 mile at the track...
Old Mar 15, 2010 | 12:01 PM
well if your car is running properly as you described then it shouldn't have anything wring, I guess it was just not the best run.
Old Mar 15, 2010 | 12:05 PM
SkylineGTR2789's Avatar
maybe you should have reseted the ECU before the DYNO especially if youve been driving around with the mods for some time
Old Mar 15, 2010 | 12:16 PM
rleroy4298's Avatar
I resetted the ECU about 3 days prior. Have you dynoed your car Skyline?
