Electronic throttle program
Old Mar 25, 2010 | 05:08 PM
Jons35's Avatar
I have a question regarding the programming of the electronic throttle....
The factory has the throttle so that when you are shifting gears, it holds the throttle just above fully closed when you let off the gas pedal, then it drops it down completely.... Same thing when you are in 2nd or 3rd gear at hi rpm and let off the throttle completely. The throttle stays cracked for a second before going all the way to idle.... This really sux for bending corners at the peak of traction. I want the engine braking IMMEDIATELY.
The dealership service manager went back and asked a Tech if I could get this flash programmed out, and he said NO.... I call BS.
Are any of you guys familiar with what I'm talking about?? And a fix?
Can a tune shop help me?
Thanks!
Old Mar 25, 2010 | 06:22 PM
Zed 71's Avatar
Check out Technosquare.
Freeman186
Sep 6, 2023 10:07 AM
prinny
Nov 22, 2015 11:07 PM
Usman Ali
Oct 4, 2015 08:23 PM
Detailed Image
Sep 18, 2015 03:43 PM
