Only got 260whp and 255tq. Seems a little low to me...
I have the Stillen airbox but like the JWT popcharger with velocity stack way better than the STILLEN version, so I'm using that.
I measured intake temps to be 10-15* over ambient - which is right about the same as stock. But, I also heat shield wrapped my intake tubing and airbox.
There is: R2C has a good intake box, STILLEN airbox works well too.
http://www.r2cperformance.com/perfor...r-filters.html
It's still way too exposed.
If someone closed up the holes in the Stillen box, ran the the JWT popcharger with the Stillen box, and tried to get decent airflow considering the points where the stock intake draws air, it would be a good intake. I wish Motordyne was able to follow through on making an intake.
My plastic Z-tube gets hot. It's surprising how hot it gets, and I cannot imagine what it would be like if it was metal, and the filter was exposed to hot engine bay air. When Ford does a performance package and sticks a high flow intake in the Mustang engine bay, it's always sealed well, and made of plastic. Why can't someone come up with something similar for our cars. Maybe it's b/c the G35 can draw air from behind the headlight? Idk...
Just for reference, I was running a Ztube/Popcharger for the last 2 years and recently picked up an Injen CAI from a buddy of mine, and I didn't notice a damn difference in my IAT's. I am debating going back to the old setup or maybe heat wrapping the Injen.
Thanks! Sounds like I need to throw that crap out!
That exhaust is definitely not true dual.. Get as nerdy as you want about it but its not a TRUE dual. It merges into 1 pipe then back out to 2 pipes making it a dual. Not a TRUE dual.
Stillen X pipe is an incredible piece of exhaust for this car.. People need to use it.
With just the JWT pop charger and heat shield you have a lot of heat soak still. The stillen airbox does a good job sealing out the heat. Heat wrap it also, and you'll keep better air temps all the way through.
With both the Popcharger/Ztube combo and the Injen, my intake temps were 10-15 degrees above ambient, depending on if the car was moving or in slow traffic. Going from the Popcharger to the full CAI didn't improve my IATs in any noticeable amount.
nice video for sure!!
From your first post you said that the stock g dynos around 240 hp? If your only making 20 hp with all those mods, then it seems kinda low doesnt it?
)Im talking from what i read and saw from other experiments) But the mrev + spacer should be around 15hp itself shouldnt it?
unless he got a baseline that day, I dont think the stock dyno matters.
The mrev combo should yield some good hp, maybe not 15+ peak. Also adding mods doesn't just keep adding and adding hp.
for example: Mrev combo adds 15hp to a stock car and an exhaust adds 10hp to a stock car. If you paired the mods together mrev combo and exhaust you may only yield 20hp instead of 25hp. Mods dont add like 15hp+10hp+ etc + etc = 350HP !!!
One guy drove a WRX hatchback so the cam man popped the hatch and set hit *** in the back seat lol. Those creep-ups were in 2nd gear starting at 2k R's.... Should have just done a 1st gear but than again didn't want to spin out or hit a friends ride..
