single gauge for dual wideband
Old Apr 25, 2011 | 07:50 PM
the_sedan's Avatar
So i picked up an aem uego dual wideband kit. Pn30-2300 i believe. Single twin channel controller with 2 sensors and 2 gauges. Are there any gauges out there that are dual display in one single gauge? I pm'd IP about their gauge but its calibrated for use with the haltech wb kit. Does anyone know if any other gauge will work or can confirm if the aem has the same voltage reading calibration as the haltech setup?
Old Apr 25, 2011 | 07:57 PM
rcdash's Avatar
Well the "Haltech" gauge is 0-5V 10-20AFR linear, so it should work with most controllers...
Old Apr 25, 2011 | 09:08 PM
the_sedan's Avatar
And im pretty sure the aem is the same but cant check right now since im mobile. But id like to be sure before i buy something.
Old Apr 25, 2011 | 09:20 PM
GreenGoblin's Avatar
The goblin resurrection
Vei guages also make a dual display. The aem ugeo is a 0-5v output
Old Apr 25, 2011 | 09:35 PM
the_sedan's Avatar
got this from aem's site:
features:
No free air calibration required - ever
Accurate to .1 AFR
Includes white and black gauge faces
Includes black and silver interchangeable bezels
Includes Bosch 4.2 sensor for optimum accuracy and reliability
0-5v analog output included for use with data loggers and virtually any engine management system
0-5v analog output Gasoline values from 10 to 20:1 AFR
0-5v analog output E85 values from 6.6 to 13.2 AFR
0-5v analog output Ethanol values from 6.14 to 12.3:1 AFR
0-5v analog output Methanol values from 4.4 to 8.8:1 AFR
0-5v analog output Lambda values from .68 to 1.36:1
so the injected performance gauge SHOULD work. i like it better cuz it has a close matching orange display to it. so im pretty much left to choose between the IP and VEI gauge. Innovate has the xd-16 which i think would work but you'd have to switch back and forth between each bank. i want both displays showing together. and i havent found any other gauges out there so far....
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
Learned Hand
Oct 1, 2015 09:02 AM
9tray turbo
Sep 29, 2015 10:22 PM
