New Osiris Tune- Suggestions for Settings
Old Dec 15, 2011 | 08:22 PM
keithk831's Avatar
Arrow New Osiris Tune- Suggestions for Settings
I just received my base map for my G35x, and i'm starting to get a feel for the differences it's making. Right off the bat, I can tell the throttle mapping is much better (more aggressive).
Now i'm trying to compile a list of things i'd like changed in my first revision. Here are some thoughts:
1. Should I raise the rev limiter/shift point a little? I think the stock HP peaks at 6200rpm, and I don't think it ever revs higher than that. Maybe 6500rpm? Higher?
2. I decided that all I really care about is the "Power" map and stock map. I'd never use valet, and economy is probably a gimmick (a properly tuned power map will also be the most efficient map at low loads). Thoughts?
3. Idle RPM. Do I have any reason to change it from it's stock value?
Anything else I should think about doing?
Old Dec 23, 2011 | 07:59 PM
13thirteen13's Avatar
subscribed
Old Dec 24, 2011 | 12:14 AM
keithk831's Avatar
Come to find out, the shift points aren't adjustable on the 5AT. So that's out.
Old Dec 27, 2011 | 04:48 PM
Dsskyline's Avatar
You can play with torque management though for firmer shifts.
Old Dec 28, 2011 | 08:27 PM
keithk831's Avatar
Interesting...i'll have to check into that. Thanks!
Old Dec 29, 2011 | 11:19 AM
Dsskyline's Avatar
Do you have Osiris tuner?
Old Dec 29, 2011 | 01:32 PM
keithk831's Avatar
No...I have Osiris Standard and I'm being tuned by a local shop (non-dyno)
Old Jan 12, 2012 | 02:20 PM
djamps's Avatar
you will certainly have perceived gains via the remapped throttle and small gains (0-5whp maybe) from remapping the fuel tables with that depending on how far off you were before hand. you really need a dyno for real gains that can be had in the timing and cam tables.
Old Jan 12, 2012 | 03:10 PM
keithk831's Avatar
Yeah...unfortunately an Uprev dyno tuner is nowhere near me, which is why I had to go with an e-tune.
I actually saw some pretty good gains:
Stock 0-60: 8.10 seconds
Current 0-60: Averaging 7.6 seconds
These runs were done back to back with cleared learned fueling.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
paolojericho11
Sep 11, 2015 07:08 AM
whatacar
Canada
Aug 13, 2015 07:33 AM
Red G Coupe
Tuner & Dyno
Jul 30, 2015 08:32 PM
sahizzle110
Jul 29, 2015 11:36 AM
