Dyno tuned RESULTS with Mods for 05 Rev Up...SpecialtyZ
Old Aug 5, 2012 | 05:01 PM
jninja26's Avatar
First off I had this tune done at SpecialtyZ in Chatsworth, CA. Sebastian took care of the tuning and answering a hundred and one questions for me Now first of all, I was going to go to Churches, but they wanted $450 to retune even though I already had Osiris Standard Sebastian took care of me for just $275 and even took the time to look at a wheel bearing issue I was having, afterwards. I am very pleased with Specialty Z as a company/shop and Sebastian in particular. I will begin by noting my previous mods:
Z-Tube
K & N Drop-in
Full Stillen CBE
Kinetix Plenum V+
Osiris Standard
...& a butt load of DIY small preventative, performance minded maintence.
And I attest my maintence discipline to my G's relatively good numbers.
Keep in mind that the stock tune is actually an E-tune (might as well be stock- useless).
As you can see the top end of the power band WAS terrible, and of course A/F's were off all over the place. Sebastian did a great job, and i think I did as well restoring a G that was not running very well when I purchased it. To give you an idea, I cleaned TB, MAF, ran seafoam, replaced sparkplugs, switched to synthetic, changed diff fluid, changed trans fluid, replaced PCV valve, thermostat, and more.
Since this tune I replace stock cat's with Top Speed TP's and they sound absolutely terrible above 3k rpm. Right now Sebastian has my car back in the shop and were adding a little whoosh, which btw will hopefully get rid of some rasp....Adding a snail is cheaper than replacing TP's afterall, right??
Edit: In case you can't tell, I gained a peak 17rwhp and 7rwtq...not bad numbers at 265rwhp and 237rwtq for a 7-8 y/o Rev up with 92k miles.
Old Aug 5, 2012 | 05:36 PM
Jairen's Avatar
So the dyno was on the stock cats?
Nice results.
Looks like an MREV2 and ART pipes would help.
Old Aug 5, 2012 | 05:58 PM
jninja26's Avatar
Thanks. Yes it was stock cats, but I have TPs now...and a turbo otw.
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
n1smojunkie
Sep 7, 2015 02:42 AM
sick_sixspeed
Jul 21, 2015 01:59 PM
sick_sixspeed
Jul 20, 2015 10:25 PM
