Aftermarket ECU for a Naturally Aspirated VQ35DE?
Old Feb 19, 2014 | 06:58 PM
canehdian_guy's Avatar
Thanks.
So do i hook a computer up to the cipher cable then send you the information via email? And do I need a wideband? Or anything like a tuning license to reflash the ecu? Sorry, all this is foreign to me.
I think Concept Z Performance still caries the cipher cables though I haven't spoke to them directly about it.
Thanks
Old Feb 19, 2014 | 07:06 PM
seymore4's Avatar
m56
Thanks
The cipher cable connects your laptop to the car via the OBD2 port. With the uprev software you can monitor and record all the information from the ECU (all G35's 04 and newer have factory widebands so you do not need an aftermarket one) and save it as a datalog, which can then be used to tune the car remotely.
Since you were dyno tuned to begin with you already have an Osiris license on your ECU, unless you got some sort of a refund from them and they reflashed it back to stock.
No one still sells the basic cipher cables, they were discontinued last year. If they're still displayed on their website then they need to update it... or maybe they have a couple left in stock from way back when. Highly doubt it tho
Old Feb 21, 2014 | 01:59 AM
Okay great. Thanks for all the help. I'll let you know when I'm ready to tune.
Old Sep 18, 2020 | 09:18 PM
Jamie Pollack's Avatar
2003 infiniti G35 Sedan with Bose option
How do I get in contact with you?
Originally Posted by seymore4
Good luck.. let me know if there's anything I can help with
How do I get in contact with you? I have a 03 G35 sedan that I was looking to get an e tune for!
Old Sep 18, 2020 | 10:19 PM
seymore4's Avatar
m56
03 Sedan is a maybe.. you need to check the physical ECU and see which style you have. The early 03's are not tuneable.
Old Sep 19, 2020 | 11:41 AM
Other options?
well that sucks.... I have the first one... do you know other options for tuning or gargle tunes/2-step?
Old Sep 19, 2020 | 12:00 PM
seymore4's Avatar
m56
Buy a different car
Old Sep 19, 2020 | 05:57 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
He's not wrong, unless you're willing to invest quite a bit of time and parts into swapping the ECM and rewiring for a newer style of ECM (and the programming to make it work, they're not just plug n play).
Old Sep 19, 2020 | 06:55 PM
Damn...
damn... I’d rather just leave it and upgrade cars in a bit sad I couldn’t get more out of her though thanks guys!
Old Sep 23, 2020 | 02:27 PM
Jayce Williams's Avatar
G35
04 g35 m/t
I have a 04 G35 that needs an ecu I have been looking all over eBay and car parts sites and idk what to get or who to talk to and idk if I want to take it to a dealership to get the ecu I buy reprogrammed. What should I do?
Old Sep 26, 2020 | 11:50 AM
cleric670's Avatar
BANNED!!!
First take your existing ECM, look at the sticker on the front, get the MEC##-###-####f number from it and get one that has the exact same number.
Yes the dealership needs to program the replacement ECM (lets it talk to the rest of the car, will not function without being programmed, anti-theft protection), call ahead and talk to the service department, they will usually let you drive the vehicle down, YOU swap the ECM in the parking lot (disconnect your battery first and pump the brake pedal a couple times to discharge the system entirely), THEY program it.
Old Sep 26, 2020 | 11:58 AM
seymore4's Avatar
m56
Once you get the new ECU you can also bypass NATS completely with an Uprev reflash, depending on how much the dealership is going to charge you may want to go that route instead. You can flash it yourself at home, and you get a fun tune to go with it.
jeffbdye
Jun 1, 2018 03:51 PM
mbe32
Nov 13, 2015 11:09 PM
Fox843
Nov 7, 2015 05:43 PM
Learned Hand
Oct 1, 2015 09:02 AM
