Is it time a uprev tune?
Old Mar 13, 2014 | 12:59 PM
g35fnatic's Avatar
Bolt ons:
Art Pipes
TDX2
Nismo CAI
MD 5/16 spacers
My mechanic told me headers are not worth it due to his high intense labor cost and the price of itself.
Anything else I should put on before getting my tune?
Old Mar 13, 2014 | 07:40 PM
seymore4's Avatar
m56
I'd recommend new spark plugs but other than that looks like a good mod list. I agree with your mechanic headers are rarely worth the expense on these cars
Old Mar 13, 2014 | 08:20 PM
g35fnatic's Avatar
I've replaced OEM ones with NGK spark plugs, is that fine?
Old Mar 13, 2014 | 08:21 PM
seymore4's Avatar
m56
yessir it is. NGK makes a good plug
Old Mar 13, 2014 | 08:33 PM
g35fnatic's Avatar
So is it time for a tune? lol. How much does a uprev tune cost? I want a dyno and everything etc
Old Mar 13, 2014 | 08:37 PM
seymore4's Avatar
m56
I would say yes you definitely would benefit from a tune. Price depends on the shop but typically $600-800 for a reflash and tune. Or you can pick up an Osiris standard cable for around $400 then just go pay for the actual dyno tuning, should only be $300 or so. That way you'd have the cable so you can reflash back to stock and sell it used later on if you part out, check and clears codes, etc.
Also since you have an 03 you (or the shop) will have to repin the OBD2 connector before they can reflash it, some shops charge extra for that so I would check ahead of time if you're planning on having them do it.
Feel free to shoot me a PM if you've got any questions how it works.
Old Mar 13, 2014 | 09:33 PM
gary c's Avatar
By the time I'd added your mods I was throwing error codes telling me I was running lean. Had no choice but to get a Osiris tune and really enjoyed the extra WHP and torque from the tune...yes you're due!
Gary
Old Mar 13, 2014 | 10:27 PM
g35fnatic's Avatar
Gary
What do you mean by you were throwing error codes about you running lean? lol
Old Mar 14, 2014 | 05:38 AM
Urbanengineer's Avatar
Literally all the mods you listed are air breathing mods. You increased air flow away above stock and didn't retune your air to fuel ratios so your car is spotting less gas then it should (running lean).
A tune will make the Air to Fuel ratio decrease and therefore make your engine run more efficiently, cooler, and safer!
Old Mar 14, 2014 | 05:46 AM
seymore4's Avatar
m56
A proper tune will correctly calibrate the fuel delivery so that its running just right, not rich OR lean. Sometimes that means increasing the A/F ratio, sometimes decreasing.
Old Mar 14, 2014 | 01:18 PM
g35fnatic's Avatar
Could you explain to me what are the downsides of running "lean"?
And some guy from my local group is trying to sell me a license from Uprev to get my car tuned by Junor(claims hes the best tuner in America), should I do it?
Old Mar 14, 2014 | 01:21 PM
seymore4's Avatar
m56
Running lean can cause detonation, and in extreme cases wreck your motor. At best you just don't make good power. Who's Junor?
Old Mar 14, 2014 | 01:23 PM
g35fnatic's Avatar
Junior*
http://www.youtube.com/results?searc...r%20tuned&sm=3
Apparently he tunes out exotic cars and all that all over america, he travels around to different shops to tune for people.
How do I know if im running lean? Am i suppose to get a check engine light?
Old Mar 14, 2014 | 01:25 PM
seymore4's Avatar
m56
Never heard of him. The only way to know if you're running lean is to check the A/F ratio either on the dyno or with a wideband datalogging. Sometimes you get a CEL but not always
Old Mar 14, 2014 | 01:27 PM
g35fnatic's Avatar
Damn man so im guessing I should get a tune asap with my mod list? Is there a high chance im running lean lol?
