Getting Uprev on Tuesday.
Old Apr 12, 2018 | 12:36 AM
04Joe's Avatar
Getting Uprev done on Tuesday and have a few questions. How long does it take? and how many pulls do they do? Also, I just got an oil change done and my tires have maybe 5k miles on them, any thing else I should be aware of before hand or other prep work? My K&N cone air filter is less a year old too, so I dont think I need to clean/recharge it.
Old Apr 12, 2018 | 02:02 AM
deeliciousqueen's Avatar
G35 coupe 6mt
Bring a quart of oil! looks like you have an 04 non-revup, even though you just changed your oil, it is best to bring an extra quart just in case, check your dipstick before the dyno run and add if necessary. The duration varies, it could take an hour or 2 depending how skilled the tuner is.
This is just personal preference but I would opt out on your current intake setup with a cone filter especially if it is expose inside the engine bay (heat soak). Alternatives are stillen intake kit or oem rev-up airbox with z-tube.
Completely up to you.
Old Apr 12, 2018 | 02:25 AM
04Joe's Avatar
I think your talking about this "power duct" that says Stillen, came with my z-tube purchase from stillen, so i think im set there. also carry a quart of oil in my trunk at all times. 2 hours doesn't seem too bad, even if it takes a little longer. do you know how many pulls they put the car through?
Old Apr 12, 2018 | 02:34 AM
G35 coupe 6mt
Perfect, that's what I meant. I can't exactly recall how many pulls but it sounds like you are set to go. Gl and enjoy
Old Apr 12, 2018 | 03:58 AM
Scorpi0's Avatar
Make sure to post the results! This is most likely in my future.
Old Apr 12, 2018 | 09:32 AM
seymore4's Avatar
m56
How many pulls/ how long it takes depends on MANY factors. Tuner's experience/ skill level, how the car responds to the tune, if its too hot and they need to let it cool down, if the dyno works properly, how long the tuner WANTS it to take (no joke I know guys who check their email on the dyno to give it the appearance of taking longer)..etc etc.
For a dyno tune I would budget 3 hours from start to finish including strap up time.
I would strongly recommend replacing your spark plugs if you haven't in the last 25K miles. NGK iridiums either stock heat range or 1 step colder.
Old Apr 12, 2018 | 03:21 PM
04Joe's Avatar
will definitley post results. and spark plugs were done less than a year ago, i got the better option they offered at autozone. if i remember right they had a cheaper plug, but i got the ones that were a few bucks more i really dont remember the model. i know they werent a step colder though. as far as the tuner taking more time, thats super shady! they gave me a flat rate though so i'd hope they want to finish faster. the spot is reputable and Gary recommended it.
Old Apr 13, 2018 | 10:06 AM
seymore4's Avatar
m56
Almost all places charge a flat rate for a basic NA flash and tune
Old Apr 15, 2018 | 08:48 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Took about 3 hours, partly because the flex tube between the Z-tube and intake had a tear in it. They were able to tape it up to seal it, then do the pulls. I think it was a total of 8, two were partial because of the leak in the flex tube. Didn't use any oil but mine goes through a quart every 5500 miles or so. Got 19 hp and 22 lb-ft torque gains.
Old Apr 17, 2018 | 03:57 PM
04Joe's Avatar
was about right, just under 2 hours and about 5/6 pulls
Thanks everyone for the feedback
edwinisdumb15
SOCAL Meetings & Events
Aug 3, 2015 10:42 PM
g35fnatic
Video Share
Aug 8, 2014 04:14 PM
E-Ticket Ride
Feb 22, 2012 04:40 PM
Cody
Feb 11, 2008 10:59 PM
