Unichip question
Old May 17, 2006 | 11:03 AM
vodkarocket's Avatar
Modded Member
Originally Posted by markiev37
Hey Vodkarocket, I like those numbers. From some other threads I read i've been a little skeptical about this mod. may I ask who does your work?? I'm out here in San Jose. The mods i will have if I go with the chip are JWT popcharger(which is installed) and the Intimidator exhaust...Thnaks, Markiev
With just intake and exhaust, there isn't too much reason to add a Unichip- they haven't altered your A/F ratio significantly, and I doubt you would realize gains as my car did with all of the breather mods. Honestly, I wasn't so sure about the Unichip at first, but none of the local tuners are authorized from UTEC XS or EU, so I decided to go with what they know best. I ended up taking it to Scott Performance.
Old May 17, 2006 | 11:04 AM
Modded Member
Originally Posted by Disco_Monkey
Do you have to get it re-tuned once you get the cams installed?
Definitely yes. At that point, I'll also have my ECU sent out to TS for a reflash so my rev limiter can be raised to 7400 RPM.
Old May 17, 2006 | 11:06 AM
Modded Member
Originally Posted by 4DrSkyline
Very nice numbers, Boris! Now I want my car tuned even more! Can you post the dyno printout for me?
Dyno graph will be up later this week.
Old May 17, 2006 | 11:19 AM
trey.hutcheson's Avatar
One thing to think about Boris is your lower plenum. If you're going to raise your rev limiter, you might make more power up top with a revup lower plenum.
I know several people with the non-revup motors have tried the revup lower plenum with different degrees of success(little, from what I recall). But I don't know if anyone's tried the revup lower plenum in combination with a piggyback, cams, and a raised limiter.
Old May 17, 2006 | 02:52 PM
Disco_Monkey's Avatar
Boris has the revised MREV+ lower collector.
Old May 17, 2006 | 03:03 PM
Modded Member
MREV ++ or MREV2.
Old May 17, 2006 | 03:07 PM
I saw that, but at heart it's still the non-revup lower collector. I could be completely wrong, but if he's going to be running cams and rev higher, I would guess the shorter runners of the revup lower collector will let him to continue to make power all the way to redline. The non-revup lower collector basically runs out of room at around 6200, though the machined version might be different with this combination of mods.
Old May 17, 2006 | 03:43 PM
Modded Member
With my current mod configuration, I make peak power at fuel cutoff- my numbers don't reflect the same drop in HP towards the top of the rev range as I've seen with cars that have the rev-up engine with MREV or MREV+.
Old May 17, 2006 | 04:58 PM
markiev37's Avatar
Thanks for the info/advice vodkarocket. I've done my mods with Ted at scott performance also and he actually put the thought of the unichip in my head. maybe I should install the mrev along with my exhaust and also do the unichip at the same time........these mods are starting to get expensive!!!! Thanks again, Markiev
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
