G35 Sedan SHOWCASE GTG II - October 23, 2010 - Long Beach, CA
Papa, check your brake fluid. Your pads might be getting warn down and it set off the low level warning which is those three lights. By adding a little more fluid the lights go off.
Thanks Tim. It was a little below the full marker...I added some yesterday to top it off and lights are still there. I'm rolling in like this...the car seemed to drive fine last night when I took it for a quick spin. Wish me luck!
Cracks me up you guys telling Chris it's his brake fluid level.
Mine did this once and I called Chris and the first thing he said was "Oh, I bet your brake fluid is low"
Sure enough!
Sorry Chris. I researched everything I could find about B0400 and came up with nothing related. Seems like most manufacturers use the 400's range for climate control issues, but clearly that's not your problem
Sure enough!
i washed, clayed, applied cleaner wax, polish last night... Saturday morning Ill wash it again and wax before I hit the meet. What time are you anxious dudes getting there?
wow! your going all out for your. That's good.
