Bluetooth + Samsung Blackjack
Old May 17, 2007 | 01:52 PM
JMN's Avatar
JMN
Does anyone have similar combo? The phone pairs fine with the car but when I try to use voice commands to dial out, it just drops the call just when it says dialing. If I dial from phone it works fine.
Old May 17, 2007 | 02:14 PM
new2G's Avatar
I am interested in purchasing this phone, hopefully someone is successfully using it and can comment.
Old May 17, 2007 | 02:54 PM
JMN's Avatar
JMN
I turned off the Auto Connection Pop-up from Samsungs Headset manager and now the car doesn't try to dial out everytime I enter with the phone and was able to use Phonebook Name voice command to dial a number successfully. I'll try if I can do Dial xxx-xxx-xxxx too.
Kinda new into both of these things, got the phone yesterday and car today...
Old May 17, 2007 | 03:04 PM
Konazo's Avatar
what do you mean by dial xxx-xx-xxx? also on the BlackJack if you hit FN and B at the sametime its a short cut to turn Bluetooth on and off...
Old May 17, 2007 | 03:07 PM
JMN's Avatar
JMN
I mean to use voice command :dial xxx-xxx-xxxx, that's where mine used to fail, but maybe turning off that setting fixed it.
Thanks for the tip, very useful!
Old May 20, 2007 | 01:39 PM
d12a60n's Avatar
Hi - I tried to help by going here:
http://www.infiniti.com/bluetooth/
and looking for your phone under "Samsung" but didn't find it on the list. Maybe you can look at another samsung phone to see if there's any special configurations you may need. Good luck
Old May 20, 2007 | 10:27 PM
JMN's Avatar
JMN
Disabling the Auto Connection Pop-up fixed all issues, the phone works now perfectly with the car.
willdogs
Dec 8, 2015 11:32 AM
1Typhoon
Sep 25, 2015 08:45 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
beevanhuynh
Jul 14, 2015 09:06 AM
