How to transfer the Phone Book from Blackberry Curve 8320 to '07 G35X (w/o Nav.)?
Hello all,
Just want to thank you all in advance for any help that you migh have.
I just bought a new phone, Blackberry Curve 8320, great phone btw, and would like to ask G's owners here whom happened to have the same phone/vehicle that how do you transfer your phone numbers to the car's phone book from your device? I have looked/search but could not find anything anywhere, so PLEASE, let me know if you know how to do it.
Once again, thanks millions for any help about this.
Best Regards,
TH.
Best Regards,
TH.
Originally Posted by giorgios
im having the same trouble. interested in this thread because im on no mood in entering the numbers manually.
Originally Posted by 07BlueOnyx
Mine is an 8300 but the process s/b the same. Click on the options icon, then click on bluetooth then put the cursor over the paried device which in my case is "my car". Press the button menu key and choose options. Scroll down to "address book transfer" and select enable. Or use the help feature of your device - I just did and it explains a different process.
Thanks so much but I just need to reconfirm with you that your vehicle does not have Navigation system, does it? My doesn't have it, so basically I just want to transfer the important numbers that I call/receive almost daily. Once again, thank you much for your help.
TH.
Originally Posted by Shirtboy
Hello 07BlueOnyx,
TH.
TH.
it worked for me. just click download phonebook on the navi then go to ur phones bluetooth setup and press the menu button on the left side of the scroll ball and go to enable phonebook transfer.
Originally Posted by infi07g35x
that list is not correct. It said my blackjack was compatible but no windows mobile phone is. I now have an 8310 and it is compatible. I have nav
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
