Front Door Speaker specs/replacement options
Old Mar 4, 2009 | 09:53 AM
mvppsu's Avatar
I am a new owner of a 2008 G35S 6MT sedan with Prem & Nav. I would like to upgrade the stereo by installing a sub and front component speakers. I would use seperate amps for the sub and front speakers. The rear door speakers would be left stock with the stock amp.
I've found a lot of info by searching the forums, but I have not been able to find the available mounting depth in the front doors.
In particular I would like to know:
Q1 What the available depth is in the factory 10" location. And has anyone replaced their front door speakers with components?
Q2 How is the navigation voice signal routed? Is it included in the head unit front left/right output?
My plan would be to:
1. Remove the 10" woofer and replace it with a 6.5" speaker with custom mdf bracket
2. Replace the factory tweeter in the current location
3. Place the component crossover in the place that the midrange speaker is currently located (or somewhere else in the door if I cannot wedge it into that space.
4. Tap into the head-unit front left & right line out and send this signal to the aftermarket amps
5. Disconnect the Bose Amp output to the front door speakers (woofer and mid)
6. Disconnect the Bose Sub Amp
Thanks,
Mike
Old Mar 4, 2009 | 10:01 AM
mvppsu's Avatar
Another thought I had, since there are already 2 sets of factory speaker wire going into the front door (mid & woofer), I could place the crossovers in the trunk and use the two sets of factory wire for the tweeter and woofer.
tiguy99
Mar 1, 2016 11:42 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
bjo16
Aug 4, 2015 09:52 AM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
